Hi Everyone,
Im converting my 69 Sprint from auto to manual and in search of the correct pedal set and z bar linkage. Anything 67-69 Firebird V8 will work for linkage but pedals are year only as most of you know.
Please PM me if you have any leads to set.
Thanks,
Matt
1969 Firebird - 4.1L OHC 6, T5 5 Speed, 8.5 10 Bolt Posi 4.11 Gear.
M,
Keep track of what it all ends up costing you to gather all the parts. My guess is it'll be alot by the time you find it all piece by piece. I'd be curious to know.
Not looking forward to the cost either. There is a restored set on ebay for 250+ which is robbery. Any leads would be appreciated.
J Offline
What I did a few years ago was locate a 400 4-sp parts car, had to go to Houston to get it but was worth the money to have the whole car. I sold a set of pedals to a member here last year for $75 I believe so they are out there. I haven't decided if I'm going to stay auto or go manual but if I end up selling one of my last two cars I will have to decide then.
Jerry Tallman
69 455/4sp Windward Blue, deluxe parchment bench seat, under major restoration
[email protected]
I got lucky when I converted mine from auto to manual, actually I was only toying with the idea when I found a box of parts at a swap meet tagged as "'69 firebird manual trans. parts". Inside was the bell housing, z-bar, pedals, push-rod, springs and a few other parts. All I needed was the trans. throw-out bearing and clutch. The box cost me $75.00. Made the decision easy.
I did have to put new bushings on the pedals.
Hank K.
Green Bay Wis.
A
A Offline
you can uses 1969 camaro,if you change the cross brace that bolt frome under dash to firewall. the difference is the camaro takes a bigger shaft where it goes pivot end of pedels. that what i did
0 members (), 560 guests, and 21 robots.
JFF 1
