#278711 11/02/13 11:38 PM
C
C Offline
Can you tell by just seeing it?
J Offline
I'm gonna say that the head number is 47 so a 69 350,
Jerry Tallman
69 455/4sp Windward Blue, deluxe parchment bench seat, under major restoration
[email protected]
S Offline
Looks different than my 400 I have for sale so I'm gonna say 350 (or 326)?
find the block number...it will tell...its on front of block under pass head...where water pump is attached..
C
C Offline
This
J Offline
Year Engine HP Engine code Trans CR Cam Head Code BBL Carb No. Misc
1965 389 256 HP XB A 7.6 066 75 / 9778775 1-2 7025060/61 A/C Block Casting # 9778789 Should have full head production number under valve cover - 9778775
1966 389 290 HP XB A 7.6 066 091 1-2 7026060/61 A/C Block Casting # 9778789
1967 400 260 HP XB A 7.6 254 142 1-2 7027060 Block Casting # 9786133
1969 350 265 HP XB A 9.2 254 47 1-2 7029062/72 45 degree int. Block Casting # 9790079
1977 350 170 HP XB A 7.6 793 6X 1-4 17057262 Block Casting # 488986
1978 301 140 HP XB A 8.2 471 01 1-2 17058160 Block Casting # 525934
Jerry Tallman
[email protected]
C
C Offline
So its one of those ? Im confused
J Offline
Yes that code was used for those engines, you need to get the date code or block code both located by the dist hole
Jerry Tallman
[email protected]
C
C Offline
Distributer hole ima go see if I can find it
J Offline
Look behind the passengers side cylinder head by the firewall you will see 7 numbers on top of the engine block.
B Online: Content
Does it have the casting lug in the back of the block
C
C Offline
Just couldnt find anything little space to clean and find
Posts298,897
