Posts: 245 |
Can you tell by just seeing it?
Posts: 1,287 |
I'm gonna say that the head number is 47 so a 69 350,
Jerry Tallman 69 455/4sp Windward Blue, deluxe parchment bench seat, under major restoration [email protected]
Posts: 168 |
Looks different than my 400 I have for sale so I'm gonna say 350 (or 326)?
Posts: 20,054 |
find the block number...it will tell...its on front of block under pass head...where water pump is attached..
Posts: 245 |
Posts: 1,287 |
Year Engine HP Engine code Trans CR Cam Head Code BBL Carb No. Misc 1965 389 256 HP XB A 7.6 066 75 / 9778775 1-2 7025060/61 A/C Block Casting # 9778789 Should have full head production number under valve cover - 9778775 1966 389 290 HP XB A 7.6 066 091 1-2 7026060/61 A/C Block Casting # 9778789 1967 400 260 HP XB A 7.6 254 142 1-2 7027060 Block Casting # 9786133 1969 350 265 HP XB A 9.2 254 47 1-2 7029062/72 45 degree int. Block Casting # 9790079 1977 350 170 HP XB A 7.6 793 6X 1-4 17057262 Block Casting # 488986 1978 301 140 HP XB A 8.2 471 01 1-2 17058160 Block Casting # 525934
Posts: 245 |
So its one of those ? Im confused
Posts: 1,287 |
Yes that code was used for those engines, you need to get the date code or block code both located by the dist hole
Posts: 245 |
Distributer hole ima go see if I can find it
Posts: 104 |
Look behind the passengers side cylinder head by the firewall you will see 7 numbers on top of the engine block.
Posts: 1,540 Likes: 41
Posts: 1,540 Likes: 41 |
Does it have the casting lug in the back of the block
Posts: 245 |
Just couldnt find anything little space to clean and find
Posts298,897
142
