Posts: 354 |
Does anyone know what type of finish is supposed to be on the Phillips Head bolts that connect the inner fender wells to the core support in the front of a 1968 Firebird? Are they supposed to be Phosphate? Zinc? I bought a repo set from Ames and they are shiny silver plated at this point.
Dave
Posts: 1,015 |
Mine is a 69 and these two bolts on either side have been protected by a respray since 1986. The paint scrapes off by using a thumb nail and when looking at them through a magnifying glass they do not have any rust (even inside the philips slots) and have a very dark gray color. I "might" be able to take a cell phone pic but no guarantees.
Posts: 3,220 |
I got the master body kit from ames and it was stocked with phosphate color ones.funny they have two different version. I did see when you bought them single it was zinc.
Posts: 3,220 |
These are the one that come in the kit. These are from AMK. Phosphate 4.00 http://www.amkproducts.com/default.htmG-6915 RADIATOR SUPPORT > FENDER GUSSETS PH WAFER SCREWS
Posts: 520 |
Mine were aged they were gray metal. I pulled them off the car, they were original. the new ones were a shiny metal. Don't know if they are painted at all, but as I said the originals were tarnished gray metal. This is for a 67 Firebird. Ames sells them these match the originals perfectly on 67's. FB703K
Posts: 354 |
Harold,
Not finding a picture of these phosphate screws on the AMK site. Do you have a picture you can send me? If AMK says they should be phosphate, I would assume that is correct. But as you stated, strange that they are zinc when buying the 703K screws together in from their catalog. No other bolts/screws are shiny on the body, so not thinking these should be either.
Posts: 3,220 |
I can not find picture on the site. You may call them and get some additional information.
This is about the best I have with me.
Posts: 3,220 |
Took this picture this evening for you.
Posts: 354 |
That certainly looks correct Harold. I will blast and phosphate mine. Thanks!
Posts: 395 |
How will you phosphate them?
1968 Firebird 400 4 Speed 68FB400
Posts: 354 |
The shop where my bird is at has a phosphate pot set up. Very easy for small parts...just blast them and stick them in the pot...instant phosphate. Does not fit large parts.
If you need some done Gordy, I can do them.
Posts298,896
1 members (Turquoise68),
251
