Posts: 120 |
These seem to be pretty good with closed chambers and 72 cc. will give my 400 9.2 CR up from 8 right now. What are you thoughts on these 670 heads? http://www.kijiji.ca/v-engines-and-engin...s-670/598340877
1968 Firebird, 350 4V, TH350 with trans-go, 69 slap shifter, 8.5 inch 10 bolt 3.42 posi
Posts: 1,541 Likes: 41
Posts: 1,541 Likes: 41 |
Don't assume on CC of heads, they all should be checked. You should figure in the cost of machine work for a rebuild. I personally don't recommend re using 40+ year old valves on any rebuild.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
67 400's with 670 heads had 10.75:1 CR. It should be the same with a 78 400.
Posts: 5,108 |
If untouched could be any where from 72-74cc. And cr may not be 9.2 if go'n by specs with 78 factory stock pistons since they are chamfered on the outside.
Posts: 120 |
The pistons are crappy cast stock replacement 30 over from an older rebuild they aren't chamfered, but have the 8 valve reliefs. I cc'd them, they are 14ccs. .025 in the hole.
Current heads are ported 6x-8 milled to 90cc, I cc'd them.
What is the ball park figure on a rebuild?
Thanks!
560
