#293038 10/14/14 03:11 AM
M Offline
Had a bad fire at one of the places where I was storing parts. Need to replace the following. All parts are for a 69 FIrebird Convertible.
The easy stuff first.
1-Inner and outer heater box non a/c.
2-Glove box lock assembly. Have an extra glove box but no lock.
3-Clear 1/4 glass pretty sure right side with chrome that accepts the weather strip.
4-Upper and lower control arms.
5-Outer core support to fender gussets right and left.
6-Hood striker plate assembly with latch and horns.
Now the hard stuff.
1- 69 Nodular rear end.
2- Front cocktail shakers and brackets
3- NOS frame bushings, control arm bushings, leaf spring shackle bushings etc.
Thankfully the rag top is fine. Just a little smoke.
C
Hi
Scott here .....1st of all sorry to hear about the fire.....glad it wasnt worse...
I have a set of pit free 69 Firebird not 67 or 68 upper and lower control arms up front...
they are from a 69 350 firebird convert that is being prostreeted ....with 69 dated power steering and a factory quik ratio 2.25 box...
the car was never wrecked and retains all its original body panels...I have the box and center linq assembly also..
from tie rod to tie rod and idler arm all look original... they are going art morrrison on it..
the car has sonly 77,000 original miles... the arms are still a bit dirty, but the car was an eastern Washington
dry car that looked to have alwas been garaged.... super dry floors and body panels...
pictures and price at [email protected]
also I have an outer heater box with a nice quiet 9 dated fan motor also,, may also have a late 68
motor also if your into dates,,,, there is a guy here on the seaattle craigs list with subframe
nos bushings but he got a high price on em ....
Scott
I have a inside heater box and left and right fender gussets
I have the inner and outer heater box with clips for heater core intact!
also have extra outer braces for core support(fender support)
I should have an extra hood latch and a few other parts but no upper plate!
i have the original rear end out of my 69 convertible
call me or email
Regards Bill S
sorry to hear about the fire!
Bill Speer
[email protected]
520-490-9097
My 1967 Firebird 400 4 speed driver
1969 Firebird Convertible (under restoration)
[Linked Image]
M Offline
I have to head over there to find out what was next to the car. I am certain the 69 latch or hood lock I got from Craig was in the hot side of things.
http://www.nwitimes.com/news/local/lake/...d7598dc40a.html
It occurred to me I might need kidney pans too. But again they might be with the car.
I am going over there Thursday and sort through the boxes. I have to take some temporary power.
Shoot me a pm with the prices on this stuff and shipping to 60451.
Thanks,
3 Offline
I may have an extra glove box lock also I will look tom.
Was your car a auto or man. ?
333Fitter #293082 10/15/14 10:01 AM
M Offline
4 speed.
dfb Offline
pm sent.
dfb #293120 10/16/14 09:50 PM
M Offline
Just an update on things. Still need for 69 Firebird
3-Clear 1/4 glass right side
4-Outer core support to fender gussets right side
5-Hood striker latch
6-Gas pedal assembly.
Now the hard stuff.
3- Rear seat 1/4 kidney pans for convertible
Thanks,
Casey
dfb Offline
I have the glass, cocktail shakers, fender gussets and the entire hood latch set up. also have a Pontiac posi chuck, but not the complete axle housing. Might be able to dig up a glove box lock.
U
U Offline
What does it mean when you say "Nodular" rear end?
USMC_Ordy #293135 10/17/14 12:17 PM
M Offline
Here is the answer.
Just a big N on the center. For steeper gears. Car came with a M-21 and a ZK rear. Guess he must have liked a high revving engine and of course to replace rear tires.
http://www.firebird400ho.com/nodular-rear-end-date-codes/
They are out there but goofy expensive. We are going to delicately pick through the rubble to see if we can find the differential and the brackets for the cocktail shakers.
But there are nine vehicles that went up in smoke and about ten thousand plus square feet of rubble.
Early 69 – 9795107
Late 69 – 9795124
U
U Offline
Thanks! That is good info to know. You learn something everyday.
M Offline
First of all, I want to thank everyone for their assistance in getting me up and running. I
I have been in contact with those of you and await the shipping fees etc and payment logistics so i can get moving again. Five steps forward and three steps backward is not too bad when you have folks who share the same passion.
The response has been overwhelming and I hope to someday personally thank each and everyone of you.
1-Inner and outer heater box non a/c.--- Looks like Bill Speer will be providing.
2-Glove box lock assembly. Have an extra glove box but no lock.- Still need.
4-Upper and lower control arms.- Scott wrap those up and I still might go for that steering box.
5-Outer core support to fender gussets right and left.- It is in the mail to me.
6-Hood latch for a 69- Still needed. But someone is looking for it.
Now the hard stuff.
1- 69 Nodular rear end.- Still looking
2- Front cocktail shakers and brackets- Some folks have them and I will make a decision soon.
3- NOS frame bushings, control arm bushings, leaf spring shackle bushings etc.- Now covered.
I also found I need a gas pedal assembly. I truly forgot what mine looked like, Not sure if it is different from a Camaro or not but if anyone has one that they can send a picture of I would sure appreciate it. Bill Speer seems to think he has one so hopefully he does.
If not send a picture to me at [email protected].
Thanks again---Casey
dfb #293507 10/31/14 11:09 AM
M Offline
Just an update.
Still in need
1- Gas pedal assembly 69 Firebird
2-I had two complete ashtray assemblies including the trim that screws to the dash. I am looking for workable oem units. I did not realize they were there until I found some of my other parts in the rubble and two very deformed ash tray assemblies.
3-Glove box latch assembly or entire glove box
4-It seems like it would be simple to find but---can't find the right side core to fender support bar. I found my left one in the rubble now I have three left hands. Anyone need a left side. One is a little toasty with a nice blue coat complements of the steam treatment it got.
Looking for workable oem stuff.
Hello Maria and Casey. I have some parts that you need. I have a 69 ashtray and a 69 glove box door, complete with lock. I'll be kind of busy tomorrow but if you want pics, I could get them to you late tomorrow or Monday. Let me know. Frank.
M Offline
Saw that you were needing bushings for springs. When I rebuilt my 68 I was able to get original quality items from St. Louis Spring off of samshepard Drive in downtown St. Louis. It has been 10 years or so, but might be a place to start.
9ySPph
DID you still need the gas pedal?
Bill Speer
[email protected]
520-490-9097
[Linked Image]
0 members (), 560 guests, and 21 robots.
JFF 1
