I have several new rubber bumper items.
New Radiator Support Filler Panel Rubber Bumpers Stoppers 6.00 shipped
truck lid rubber Bumpers - 2.00 shipped
1967-1979 Windshield Wiper Motor Grommets - 6.00 shipped
Radiator Mounting Set - 6.00 shipped
Many other new bolts and screws. If you need a screw or bolt I may have it. Just ask. I have several slotted head bolts used for water pumps and other items.
3 Offline
H,
What's included in the rad. mounting kit ?
It has the screws and rubber well nuts to attach the radiator to the core.
3 Offline
ok cool I will take the rad. support filler panel rubbers & the rad. mounting klt.
p.m. me your address & I'll get a m.o. out to you next week.
Some more misc bolts, clips, grill grommets , slotted water pump bolts ect
all new sets ...
Exhaust hanger bolts set
steering column seal retainer screw set
Fan blade spacer bolt set
steering column rag joint bolt
pitman arm nut and lock nut
windshield wiper motor bolt set
ignition coil bolt set
rocker molding screws
grill clips and bolts
fuel sending unit lock
door window sash nuts
Trunk Latch striker bolt set
misc body bolts and nuts
Many more not in photo.
M Offline
Hi Harold, I'll take the trunk bumpers.
Thanks,
Mike
