New Radiator Support Filler Panel Rubber Bumpers Stoppers 6.00 shipped truck lid rubber Bumpers - 2.00 shipped 1967-1979 Windshield Wiper Motor Grommets - 6.00 shipped Radiator Mounting Set - 6.00 shipped
Many other new bolts and screws. If you need a screw or bolt I may have it. Just ask. I have several slotted head bolts used for water pumps and other items.
Some more misc bolts, clips, grill grommets , slotted water pump bolts ect
all new sets ... Exhaust hanger bolts set steering column seal retainer screw set Fan blade spacer bolt set steering column rag joint bolt pitman arm nut and lock nut windshield wiper motor bolt set ignition coil bolt set rocker molding screws grill clips and bolts fuel sending unit lock door window sash nuts Trunk Latch striker bolt set misc body bolts and nuts Many more not in photo.
