Posts: 317 |
I'd never paid attention to it, but after taking my intake off today I see that it has two PCV valves installed, on on the valve cover and one cover below the intake (intake valley pan?). Both run to a port on the intake, just in front of the carb. 67 firebird supplement shows one setup using the valve cover and one using a valve behind the carb I think.
Any reason that there would be two installed? If it matters, valve covers are the sealed type (no breather).
Posts: 3,220 |
Originally there was a pvc valve in valley pan and the hole in valve cover was a tube that went to the breather connected to a little filter.
Posts: 317 |
What that the same for all first gens? Non-California cars anyway.
Posts: 3,220 |
Yes I'm sure on the 8 cly Not sure about the 6cyl's.
Posts: 317 |
Alright, last question I think. What is the gasket between the water pump and intake called?
Posts: 3,220 |
Ames Performance
Part# FN770B Description 1967-81 TIMING COVER TO INTAKE SEAL (RE) Net Comments PONTIAC ENGINES ONLY. O-RING SEAL THAT GOES IN THE WATER PASSAGE BETWEEN THE INTAKE MANIFOLD AND TIMING COVER.
Posts: 5,108 |
Need a vent into crankcase to evacuate fumes and pressure build up.
Posts: 317 |
Thanks guys, Ames the only place that sells these. Napa maybe?
Posts: 3,220 |
The Felpro intake gasket set comes with it. Napa part FPG MS9980 but the felpro set at napa cost 22.99. Summit is 13.97.
That is the only option I see where it is in the intake gasket sets. Maybe they can match up a o-ring from out of the kit.
Posts: 317 |
Ya, only reason I asked was shipping from Ames was $10 on a $2 seal. I'll just order two from them.
Thanks again Harold.
2 members (Geoff, Jimc2002),
469
119
