Posts: 39 |
Well, I have sticker shock. I finally added up all my receipts for my 68 Firebird Coupe 350 3spd frame off restoration. It's been in the works for three years and I finished it this past September 2016. I bought it in running condition for $4,500. The parts added up to $14,800 and I did everything but the engine myself. Some of the big items were the engine $4,000, front disc kit $600, interior kit $850, tires $600, exhaust $450, distributer $250. I'm pretty frugal, so I was always looking for the best deal. The worst parts came from car shows, I ended up replacing some of those parts and I have a set of seat foams and covers that I didn't use. I had always though I had about $12K in it. I've attached the parts sheet for anyone wondering what it can cost for a restoration.
Posts: 39 |
Here's the spreadsheet. Guess I'm over the limit for attachments. P/N QTY PRICE EA TOTAL Front Bumper $202.26 Rear Bumper $149.95 Wheel Opening Mlding Set $82.95 Windshield Mldg Clips $16.95 Radiator Core Support $95.00 Battery Box w/Clamp/Bolt $24.10 RH Fender Extension $43.95 Inner Fender Well RH $126.00 1967-1968 Firewall Wiring Gutter $17.00 Trunk Paint Kit $49.99 Gas Tank Paint $9.99 Paint Stripper $43.01 Dash Vents $20.00 Leaf Rear Springs $126.84 Install kit $84.00 Filler Neck hose $9.95 Fuel Tank Clamp $5.50 Ship $47.50 REAR DRUM BRAKE HARDWARE KIT $10.00 Transmission Switch Firebird Quarter louvers set of 12 $69.99 Pillar Molding Pair $64.99 Master STD Interior Screw Kit $122.00 FW688T Windshield Glass Tinted $118.20 Windshield seal $15.28 Rally II Center Cap Set - Set of 4 $119.95 OER Sill Plate, Chrome Finish Pr $47.90 Engine $2,275.15 $983.00 $800.00 10W-40 Racing Oil Battery $106.50 Spare Tire Cover $39.00 Temp Sender $19.50 Voltage reg $29.00 Fuel pump $43.00 Vent pipe Grommet $3.00 Timechain stud $3.00 Hose Clamp Kit $16.00 Cowl seal Kit $20.00 Clutch Pedal Bumper $3.00 GM Decal $5.00 Jack Decal $5.00 Cooling Decal $5.00 Emission Decal $5.00 Spray paint $8.54 Header Bolts $7.19 Discount -$4.00 Air Filter Wrong one $7.64 Adhesive $23.39 Tax $1.42 Air Filter $8.64 Paint $127.01 $180.79 Rad Support Mount $35.00 Body Hdwr $14.00 Clutch Rod Seal $6.00 End Link Kit $14.00 Lwr Arm $119.00 Upr Arm $109.00 Lwr Arm $119.00 Upr Arm $109.00 Disc Bk Kit $605.00 Clutch Fk Boot $8.00 Sway Br Bushings $20.00 Ship $50.00 Htr Box Gasket Set $20.00 Carb rebuild $27.13 Gear Lube $5.77 fuel cleaner $5.28 tax $0.75 Autozone $15.99 Hood Emblem $39.95 Fender Emblem $76.95 Glove Box Emblem $21.95 Fender Emblem $53.90 Fuel Door Emblem $29.95 Speaker $39.95 Seal Plates $69.95 Discount -$51.80 Ship $18.80 Distributor $247.99 Coil $37.97 Tires $663.60 Ball Joint Boots $8.00 Door panel Clips $8.95 Wx Strip Pins $2.95 Ship $4.99 Seat Belt Decal $20.98 Sail Panels $32.79 Alternator $44.99 Starter $44.99 Spark plug $17.92 Rad Cap $6.29 Ign Wire Set $42.29 Antiseize $6.74 Fuel Filter $13.49 Tax $15.33 Window Crank $17.98 Key $4.99 Key $4.99 Hood Insul $27.99 Rear View Mirror $49.99 Ant $49.99 Air Cleaner Decal $5.99 Trunk Divider $26.99 Hood Insul Clips $19.99 Spare Tire Hold down $4.99 Tire Trim Rings $99.99 Ship $19.95 Ins $3.95 Discount -$31.40 Guage Console $46.97 Exhaust Kit $453.97 Headlight $15.94 Headlight $15.94 Sealant $26.88 Reducers $25.97 Discount -$20.00 Radiator $262.26 Thremostat & tubing $13.11 Seat Foam $179.98 Hdliner Moldings $69.99 Wshield Molding $39.99 Rear Inner Molding $69.99 Bushing $2.99 Wshield clip $14.99 Svisor suprt $39.98 Wheel Paint $16.99 Wheel Paint $16.99 Sail Panel Blk $39.99 Discount -$113.00 Ship $83.85 Ins $3.95 Trunk Mat $29.95 Shifter Boot $24.95 shifter Boot Retainer $14.95 Discount -$10.48 Ship $15.96 Spray Adhesive $12.49 Door Handle Lock Gaskets $11.72 Pk Brk Grommet $3.74 Wx Strip Kit $250.99 Frt Spoiler $48.99 Rear Spoiler $119.99 rear Spoiler Mt Kit $4.99 Qtr Window Molding $79.99 Rglass Sealer $12.99 Discount -$27.50 Ship $39.95 Ins $3.95 Tubing $4.14 Gear Oil $10.26 Tax $1.22 Steering Wheel $156.99 Pk Bk Grommet $4.99 Ship $9.00 Paint Metal Mask $39.96 Ship $5.95 A-Arm Splash kit $18.95 Fastner Kit $199.95 Rubber Bumper Kit $19.95 Park Light $99.95 Park Light $99.95 Ship $24.89 Paint Book $18.22 Rad Petcock $4.99 F/W Pad $39.99 Vinyl Top $148.99 GM Htr Hose set $24.99 Rad Nuts $3.99 Vinyl Top mdlg $107.99 Wshield clip upper $14.95 Dash Bezel Set $23.95 Wshield clip lwr $14.95 PCV Valve $2.99 Interrior Kit $844.99 Rad Hose $9.99 Rad Hose $8.99 Vly Pan Grommet $4.99 Mtr Mt $9.99 Mtr Mt $9.99 Discount -$109.18 ship $119.80 ins $3.95 Paint Engine $13.98 Paint Engine $6.99 Xmisson gasket $5.99 Xmisson Seal $4.29 Clutch Stud $14.00 Xmission Mt $6.19 Eng Mt $12.98 Clutch $110.99 tax $10.06 discount -$26.31 Paint Engine $13.43 Gear Lube & Sealer $19.32 Gas Tank Sock $8.10 LH Wheel well 1/4 patch $35.10 Gas Tank Neck outer $24.30 Gas tk mtg kit $9.00 gas tk hdw kit $3.60 Gas tk Brace $43.20 ship $20.00 Fuel Hose $3.44 Engine Gasket Kit $82.99 Paint $7.60 Paint $5.63 Spot Putty $7.82 Felpro Gasket Kit $62.42 Tax $5.12 Car $4,500.00 TOTAL $18,564.80
Posts: 7,719 |
Rest easy. My car is almost out of paint and then I have to put the interior in. My Excel spreadsheet for my resto mod stands at $53K.
But that's spread over 20 years and I splurged on a lot of things like my 455 engine, aftermarket seats, NOS front fenders, added factory options (that the car did not come with) and a HD 4-pinion posi that had to be rebuilt twice. I wanted it my way.
Posts: 10,338 Likes: 3
Posts: 10,338 Likes: 3 |
Looks like a bargain to me.
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
Posts: 1,923 |
I've been afraid to add all mine up! Not sure I really want to know.
Posts: 2,405 Likes: 1
Posts: 2,405 Likes: 1 |
Don't be too shocked, I have more than that in the engine and I did it all myself except the machining of the block which the machinist screwed up,
Posts: 2,157 |
You did well! We're over $40k for a similar rebuild back in 2008-2010. Your Bird looks very nice
Posts: 1,858 |
I'd say you did very good...
Posts: 135 |
You did AWESOME! Great job!
I paid $21,500 for my 69 back in August. It's a numbers matching 350 2bbl A/C TH400 car, new interior, body is almost ready for paint (in black primer), has a new 461 (about $7K in receipts just for that), Wilwood brakes, Vintage air, etc. etc.
Considering mine still needs paint, suspension gone through, a couple trim pieces, and a few other random things, I'm still several thousand bucks away from where you are. You made out well, congrats!!!!
Alex
http://www.TheFOAT.com/92GTA1969 Pontiac Firebird w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior. 1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
Posts: 613 |
That sounds like a bargain to me. You did very well and the car looks fantastic.
I don't know how much I have in my '67 convertible, but I'm sure it's well over $30,000, and I still have a few little things left to do.
Bruce
'67 Firebird Convertible
Posts: 28 |
and taking her out for a sunday drive, Priceless !!!!!!!!!!!
Posts: 67 |
$15k, that's it? That is one helluva bargain if you ask me. The car looks great and looks like you spent a lot more. I will have most of that amount in body work on mine. I am hoping to be able to get mine done in the $20k-$25k range, hoping.
Shane
1969 Convertible Pink
Posts: 3,615 |
Posts: 9,027 |
I agree, not bad, I stopped counting at the end at $39K and change....I'm sure I have another thousand in to it...and I want redlines now LOL
Posts: 6,758 |
Hi Dave, ... And in US dollars to boot! Chump change! lol
You did well my friend.
Posts: 20,054 |
I think the answer to the original question is : how tall is a tree?
I think the answer to the original question is : how tall is a tree? That's easy! 92 5/8". That's why they use that length for pre-cut studs!
Posts: 6,161 Likes: 51
Posts: 6,161 Likes: 51 |
I think the answer to the original question is : how tall is a tree? That's easy! 92 5/8". That's why they use that length for pre-cut studs! I went to Home Depot the other day and asked for a nice 2X4. They ask me, "How long do you want it?" I told them, "I plan to keep it forever".
Jim '68 400HO Conv.
Posts: 20,054 |
I think the answer to the original question is : how tall is a tree? That's easy! 92 5/8". That's why they use that length for pre-cut studs! LOL
Posts: 20,054 |
I think the answer to the original question is : how tall is a tree? That's easy! 92 5/8". That's why they use that length for pre-cut studs! I went to Home Depot the other day and asked for a nice 2X4. They ask me, "How long do you want it?" I told them, "I plan to keep it forever". good!
Posts: 12 |
Your car looks great and that is a bargain!
Posts: 203 |
I think you did incredibly well! Your car looks great and I hope you enjoy it. I'm way over what you've invested in my 69 and it was a good car to start with.
Posts: 6,758 |
My toilet is plugged with cash! F'n money pit man...but I love every minute of it! lol While I still have a pot to piss in ... I progress...
Posts: 23 |
Great job on the car and the budget! I think the biggest accomplishment was finding a car that appears like a great start that looked complete AND ran... for $4,500? That's rusted out project car money with no motor or interior! Every time I look for a car, this is what 5K buys you : https://greenville.craigslist.org/cto/d/firebird/6643341836.html
1968 Pontiac Firebird - 250/3Spd 1967 Chevrolet C10 - 350/700R/3.73 1965 Ford Mustang Coupe - 289/T5/3.25 2015 Silverado Z71 - 5.3L - 2011 Ford Mustang - 3.7L -
New Member
New Member
Posts: 4 |
I must be doing something wrong
Car 6000 Engine 14000 Trans/clutch 5600 Rear end/disc brakes 2500 Headers 800 Exhaust 500 Paint/ body 12000......... hopefully geez I’m at 40k+ and I’m not done.
Car 6000 Engine 14000 Trans/clutch 5600 Rear end/disc brakes 2500 Headers 800 Exhaust 500 Paint/ body 12000......... hopefully geez I’m at 40k+ and I’m not done. Nope, you are in the same club as everyone else. Spend $50k on restoration to be awarded with a car worth $25k. Grrrr!
New Member
New Member
Posts: 4 |
Car 6000 Engine 14000 Trans/clutch 5600 Rear end/disc brakes 2500 Headers 800 Exhaust 500 Paint/ body 12000......... hopefully geez I’m at 40k+ and I’m not done. Nope, you are in the same club as everyone else. Spend $50k on restoration to be awarded with a car worth $25k. Grrrr! Lol well at least I know I’m on the right track!
Posts: 7,719 |
I have kept an Excel spreadsheet through the entire 20 year process. I'm at 55K I do NOT talk about my Firebird with my financial advisor as I already know he is very much against purchasing RV's and solar panels.  Hey, it's a hobby!!!!
New Member
New Member
Posts: 2 |
I would say you did very well! I also keep a spreadsheet on all my builds so I can can ensure I am never upside down on my cars. As a hobbyist I don't keep track of my hours because if I did, I would certainly be in for a very large build cost. I do everything except machine work myself (yes, I paint my cars as well :))
Posts298,896
1 members (Jimc2002),
129
