M Offline
WANTED: '69 Firebird_Bracket Console Escutcheon to Shifter Housing.
Item 33 in the attached picture. Must be a 1969 part. The 1968 part is different.
Thanks, Mark
U
U Offline
Have you tried Franks Pontiac? http://www.frankspontiacparts.com/ Might be a hard part to find since most probably wont part with it without selling the whole shifter. Will keep an eye out for one.
M Offline
Thanks for the link to Franks Pontiac Parts. I'll check it out. Yes, I knew going in this was a long shot for the reason you mentioned. If I cannot find the part in a couple weeks, I plan to modify my 1968 bracket to make it work.
I'm pretty sure I have one but would need to have $50 plus shipping for it, If you think you're still interested, just get back to me and I'll take a look and get back to you tomorrow. Frank.
M Offline
Hi frankyboy428, thanks for helping out, but I now believe that my top plate is actually a 1969. It was warped a bit and when I straightened it out, it fit much better. Thanks again, Mark
S Offline
Did you find a 69 top plate you were looking for? If not I think I have one. $20 if you need it. Let me know and I can upload or send a picture. I'm not sure of the difference between 68 and 69 as you mentioned though so we would have to check to be sure it what you needed.
M Offline
Yes, mine turned out to be ok. It was just warped a bit. Once straightened, it was fine.
Posts298,897
1 members (Dennis in Indiana), 161 guests, and 25 robots.
JFF 1
