Looking for a 3.08 gear set up (ring and pinion). Also looking for a posi carrier as my current posi carrier with 2.73 ratio will not support 3.08 gears. Let me know what you have. Thanks!
OK, so I got my gears, -still looking for a posi carrier. The series carrier I need should have casting/part number 9784972. I can even trade you for mine, which accepts up to 2.93 gears and is posi and OEM.
Thanks, I'm aware of that but want a rebuildable GM unit, I like the cone clutch vs carbon clutches. Auburn is the only Mfg that makes a carrier for 308s. If Eaton would sell them I'd jump on it.
