#313016 08/05/17 01:12 PM
Looking for a 3.08 gear set up (ring and pinion). Also looking for a posi carrier as my current posi carrier with 2.73 ratio will not support 3.08 gears. Let me know what you have. Thanks!
I have a nice 3.08 set for Pontiac. Tim.
I also have a nice 2.93 gear set. Alll gm
PM sent.
What is the tooth count on this set?
OK, so I got my gears, -still looking for a posi carrier. The series carrier I need should have casting/part number 9784972. I can even trade you for mine, which accepts up to 2.93 gears and is posi and OEM.
O
O Offline
Thanks, that will be my backup plan if no one has an old original unit.
I have an original posi unit already gone through and checked out by a reputable builder. If you are interested. It is the one you need.
What was wrong with it and how much you need for it?
Anyone? Found ring and pinion. Still looking for a posi differential/carrier only that will work with 3.08 gears.
O
O Offline
Auburn makes 2 versions for the 8.2 BOP, that'll work with 3.08's. Sold by Summit and lots of other places.
http://www.ronsmachiningservice.net...-hp-posi-differential-2-93-3-23-5420114/
http://www.ronsmachiningservice.net...differential-28-spline-2-93-3-23-542099/
But, I see now that I already posted one version of this unit. Please forgive. smile
Thanks, I'm aware of that but want a rebuildable GM unit, I like the cone clutch vs carbon clutches. Auburn is the only Mfg that makes a carrier for 308s. If Eaton would sell them I'd jump on it.
O
O Offline
"...I like the cone clutch vs carbon clutches..."
The description of the "Pro" unit says that it is the cone clutch style. Don't know if that's what you are referring to, or not.
"...Built tough with a unique cone-clutch design, Pro Series differentials deliver even higher bias torque than their other units..."
https://www.summitracing.com/parts/aub-542099
Posts298,897
0 members (), 122 guests, and 12 robots.
