Posts: 150 |
NOS Parts
-1969 Front Right and Left Headlamp surround sold as pair. $275 -1969 Subframe bushings - 3901361 X 2 - 3928380 X 2 - 3914802 X 2 - 3962720 X 2 also part 332654 White - 14008366 X 2 - 3893159 X 2 All mounting oints sold as a set $525---SOLD GM -Door handles 3064224 and 3064225 NOS $140 for set
USED Parts - Bracket for clutch spring. Mounts to front subframe - $15 - 1381721 LH and 1381720 RH Disc Brake Mounting bracket -set $75 - Heater core mounting clamps. 2 sets available - $15 - Bead blasted, filled and painted upper control arms set - $120 ball joint included new never used - Bead blasted, filled and painted lower control arm set - $120 - Lower steering column plastic cover for 67 and 68 - $10 - Harrison Manual radiator code UM on tag not a four core $200- SOLD - Full set of bead blasted and painted A/C pulleys -9790842 XB- crank -9796061 XT- water pump -9786901 XH- power steering - Set $125 - Bead blasted and painted, but some light pitting, 9796060 XF pulley Non air water pump - $50 - Refurbished 69 grill set - $125 - 69 Parking lamp filler pair - $10 - 69 bead blasted and painted, hood spring, latch, rod, correct bolts etc assembly - $150 - upper control arm shafts, bolts and washers- $15 - four piston Delco Moraine brake calipers 5456008 and 5455946- all bolts and pins. Will need rebuild - Set $135
OER Extras New in boxes of bags - 1969 OER Grill Set - $125 - 68-9 convertible top header - $90 - set frame bushings - $30 - Manual top hold down clips - $15 - Heater box mounting bolt set - $5 - Front leaf spring bushings set - $25 - White convertible top - Classic Industries Front seat foam Deluxe $85 Set - Al Knoch front seat foam Deluxe $120 Set Prices do not include shipping.
Posts: 230 Likes: 2
Posts: 230 Likes: 2 |
Are the front seat foam deluxe sets for bucket seats with or without the wires built into them? If one of them is I will take a set. I do prefer the Al Knoch set though if it has the built in wires. Shipping to 55364.
2002 Trans Am Coupe Sunburst Orange auto # matching 76 Black on Black Trans Am 400 Auto # matching SOLD 69 Firebird Convertible Windward Blue Auto # matching - Wife's Car 67 Firebird Coupe 326 HO Stick Mariner Turquoise - Fast and Loud 2012 Dodge Ram Red- Firebird Express 2013 Chrysler T&C - Wife's Grocery Getter 76 Trans Am - Built 455 4 speed Black On Black Very Fast & Loud 76 Trans Am SE 455 4 Speed Numbers Matching Black on Black 319 Made
Posts: 150 |
The Al Knochs have the wires. I will be out of town until Friday and will take them over to the store to see how much to send them. I wish they would shrink wrap them!!
I will send you a PM when I get a number.
Also attached find photos of the heater core clips. For the person that sent the PM.
Last edited by Marla & Casey; 02/05/19 11:42 PM. Reason: Someone asked for a photo of the
Posts: 635 |
Marla and casey, I would be interested in the seat foam also. are they still available?
Bill V
69 Firebird Convertible (wifes car since 1979) Goldenrod Yellow, 350, plain Jane Car was stored in garage since 1990
I need help, if anyone see's I'm going down the wrong road--Straighten me out!
Posts: 150 |
Al Knoch seat foams sold.
The others are still available.
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
I sent a PM. I'm still interested in the top. Maker? Price?
Posts: 150 |
Posts: 150 |
Posts298,897
142
