M Offline
NOS Parts
-1969 Front Right and Left Headlamp surround sold as pair. $275
-1969 Subframe bushings
- 3901361 X 2 - 3928380 X 2 - 3914802 X 2 - 3962720 X 2 also part 332654 White - 14008366 X 2 - 3893159 X 2 All mounting
oints sold as a set $525---SOLD
GM -Door handles 3064224 and 3064225 NOS $140 for set
USED Parts
- Bracket for clutch spring. Mounts to front subframe - $15
- 1381721 LH and 1381720 RH Disc Brake Mounting bracket -set $75
- Heater core mounting clamps. 2 sets available - $15
- Bead blasted, filled and painted upper control arms set - $120
ball joint included new never used
- Bead blasted, filled and painted lower control arm set - $120
- Lower steering column plastic cover for 67 and 68 - $10
- Harrison Manual radiator code UM on tag not a four core $200- SOLD
- Full set of bead blasted and painted A/C pulleys
-9790842 XB- crank
-9796061 XT- water pump
-9786901 XH- power steering - Set $125
- Bead blasted and painted, but some light pitting, 9796060 XF pulley Non air water pump - $50
- Refurbished 69 grill set - $125
- 69 Parking lamp filler pair - $10
- 69 bead blasted and painted, hood spring, latch, rod, correct bolts etc assembly - $150
- upper control arm shafts, bolts and washers- $15
- four piston Delco Moraine brake calipers 5456008 and 5455946- all bolts and pins. Will need rebuild - Set $135
OER Extras New in boxes of bags
- 1969 OER Grill Set - $125
- 68-9 convertible top header - $90
- set frame bushings - $30
- Manual top hold down clips - $15
- Heater box mounting bolt set - $5
- Front leaf spring bushings set - $25
- White convertible top
- Classic Industries Front seat foam Deluxe $85 Set
- Al Knoch front seat foam Deluxe $120 Set
Prices do not include shipping.
Are the front seat foam deluxe sets for bucket seats with or without the wires built into them? If one of them is I will take a set. I do prefer the Al Knoch set though if it has the built in wires. Shipping to 55364.
2002 Trans Am Coupe Sunburst Orange auto # matching
76 Black on Black Trans Am 400 Auto # matching SOLD
69 Firebird Convertible Windward Blue Auto # matching - Wife's Car
67 Firebird Coupe 326 HO Stick Mariner Turquoise - Fast and Loud
2012 Dodge Ram Red- Firebird Express
2013 Chrysler T&C - Wife's Grocery Getter
76 Trans Am - Built 455 4 speed Black On Black Very Fast & Loud
76 Trans Am SE 455 4 Speed Numbers Matching Black on Black 319 Made
M Offline
The Al Knochs have the wires. I will be out of town until Friday and will take them over to the store to see how much to send them. I wish they would shrink wrap them!!
I will send you a PM when I get a number.
Also attached find photos of the heater core clips. For the person that sent the PM.
Last edited by Marla & Casey; 02/05/19 11:42 PM. Reason: Someone asked for a photo of the
Marla and casey, I would be interested in the seat foam also. are they still available?
Bill V
69 Firebird Convertible (wifes car since 1979) Goldenrod Yellow, 350, plain Jane
Car was stored in garage since 1990
I need help, if anyone see's I'm going down the wrong road--Straighten me out!
M Offline
Al Knoch seat foams sold.
The others are still available.
I sent a PM. I'm still interested in the top. Maker? Price?
M Offline
PM reply.
M Offline
PM reply.
