Posts: 70 |
I lost my trunk key on a 69
Looking to see if I can remove the lock from inside ?
Has anyone here removed the back seat and tried to remove the lock ?
Thanks Mike
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
Probably impossible from inside.
Posts: 70 |
hmm I guess a lock smith is the only answer ?
Posts: 6,758 |
Yes you can remove lock from inside. If someone in the forum can send you a pic of the lock from the inside you can get an idea as to what will work to remove lock.
You need to remove a rod that goes from the key lock to the trunk latch. Remove U clip holding lock to body Pull rod out thru the key lock hole put blade screw driver into latch, turn, and trunk opens.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
You can just turn the flat rod from inside the trunk to open it. A long arm and a tool might work.
Posts: 70 |
Thanks Bob should be able to get on it somehow and hopefully turn it
Posts: 170 Likes: 4
Posts: 170 Likes: 4 |
It is the same key for the trunk and the glove box door (if nobody has changed locks during the years). Maybe you can take out the glove box lock and take it to a locksmith and have them make a new key that fits the lock. Just a thought, I'm not sure it is possible, but it might be easier if it works.
1969 Pontiac Firebird 400
1966 Chevrolet Corvair Monza
There are not that many key codes. Invite a bunch of Pontiac friends over and see if you get lucky
Posts: 2,113 Likes: 1
Posts: 2,113 Likes: 1 |
Took about a minute with a drill to get one of mine out...
Posts: 70 |
Posts: 677 Likes: 1
Posts: 677 Likes: 1 |
I have heard that the glove box lock only uses part of the trunk keys “cut†to open. So having a key made from the glove box lock won’t work for the trunk, and that you must have the key made from the trunk lock. Not sure if that’s true.
Posts: 6,158 Likes: 51
Posts: 6,158 Likes: 51 |
If you have found the "Body Broadcast Copy" under the seats or purchased the PHS "Billing History", they have both key codes. Perhaps a good locksmith or a GM dealer can make a key to the code.
Jim '68 400HO Conv.
Posts: 853 Likes: 3
Posts: 853 Likes: 3 |
I have done it many times. All you need to do is remove the back seat get some long extensions for your ratchet and a 7/16 socket, reach through to the two screws that hold the latch to the deck lid and remove them, the deck lid will open up after that.
Wade
Posts: 853 Likes: 3
You need to remove a rod that goes from the key lock to the trunk latch. Remove U clip holding lock to body Pull rod out thru the key lock hole put blade screw driver into latch, turn, and trunk opens. 69's are bolted to the body, and very hard to get to from through the back seat.
Wade
Posts: 280 |
Locksmiths aren't that expensive. Make a few calls. Find out who is reasonable. Drive over there and have a set of keys made. Done forever. No taking apart things or messing around. Yes you are out a couple bucks but it is done right.
Just my 2 cents... and your money of course!
Only issue with using a locksmith is that if a previous Owner changed the locks, then the PHS or keycodes are useless. They also can remove the glove lock and match a key to that. But won't matter if trunk lock was swapped. But its a reasonable approach to start with.
1,607
119
