#321175 02/07/19 01:07 PM
M Offline
I lost my trunk key on a 69
Looking to see if I can remove the lock from inside ?
Has anyone here removed the back seat and tried to remove the lock ?
Thanks
Mike
MT69-400 #321176 02/07/19 01:23 PM
Probably impossible from inside.
MT69-400 #321177 02/07/19 01:44 PM
M Offline
hmm I guess a lock smith is the only answer ?
MT69-400 #321178 02/07/19 01:48 PM
Yes you can remove lock from inside. If someone in the forum can send you a pic of the lock from the inside you can get an idea as to what will work to remove lock.
You need to remove a rod that goes from the key lock to the trunk latch.
Remove U clip holding lock to body
Pull rod out thru the key lock hole
put blade screw driver into latch, turn, and trunk opens.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
MT69-400 #321181 02/07/19 03:25 PM
You can just turn the flat rod from inside the trunk to open it. A long arm and a tool might work.
Bob S. #321184 02/07/19 03:38 PM
M Offline
Thanks Bob should be able to get on it somehow and hopefully turn it
MT69-400 #321196 02/08/19 02:40 AM
It is the same key for the trunk and the glove box door (if nobody has changed locks during the years). Maybe you can take out the glove box lock and take it to a locksmith and have them make a new key that fits the lock.
Just a thought, I'm not sure it is possible, but it might be easier if it works.
1969 Pontiac Firebird 400
1966 Chevrolet Corvair Monza
MT69-400 #321199 02/08/19 07:49 AM
There are not that many key codes. Invite a bunch of Pontiac friends over and see if you get lucky
MT69-400 #321200 02/08/19 08:10 AM
W Offline
Took about a minute with a drill to get one of mine out...
Ronnie S #321201 02/08/19 12:02 PM
M Offline
Thank you
MT69-400 #321204 02/08/19 01:54 PM
I have heard that the glove box lock only uses part of the trunk keys “cut” to open. So having a key made from the glove box lock won’t work for the trunk, and that you must have the key made from the trunk lock. Not sure if that’s true.
MT69-400 #321205 02/08/19 02:07 PM
If you have found the "Body Broadcast Copy" under the seats or purchased the PHS "Billing History", they have both key codes. Perhaps a good locksmith or a GM dealer can make a key to the code.
'68 400HO Conv.
MT69-400 #321208 02/08/19 06:31 PM
I have done it many times. All you need to do is remove the back seat get some long extensions for your ratchet and a 7/16 socket, reach through to the two screws that hold the latch to the deck lid and remove them, the deck lid will open up after that.
Wade
Gus68 #321209 02/08/19 06:36 PM
69's are bolted to the body, and very hard to get to from through the back seat.
Wade
MT69-400 #321213 02/09/19 10:39 AM
U
U Offline
Locksmiths aren't that expensive. Make a few calls. Find out who is reasonable. Drive over there and have a set of keys made. Done forever. No taking apart things or messing around. Yes you are out a couple bucks but it is done right.
Just my 2 cents... and your money of course!
MT69-400 #321215 02/09/19 12:02 PM
Only issue with using a locksmith is that if a previous Owner changed the locks, then the PHS or keycodes are useless. They also can remove the glove lock and match a key to that. But won't matter if trunk lock was swapped.
But its a reasonable approach to start with.
0 members (), 1,658 guests, and 127 robots.
