A
ahs
Offline
A Offline
Hi there,
I'm in the process of assembling my 1968 Pontiac 400 after a rebuild, and wondering if someone can recommend an oil priming shaft that will work on a 1968 Pontiac 400 engine?
I've read of some people making one out of an old distributor, but haven't found any references to an off the shelf tool that just works. I would prefer to not have to spend too much time priming the motor.
And yes, I know my drill must spin counter-clockwise to prime the oil system:)
Thanks!
I made one for my OHC with a long bolt that I cut the head off. I then used a grinder to shape the end. The V8 distributor looks similar to the OHC so it should work. Use a slightly smaller diameter so it doesn’t rub the walls.
Larry
1967 Sprint Convertible
A
ahs
Offline
A Offline
ok, if no one comes up with a part number, that sounds simple enough!
M Offline
O
O Offline
I think the same one that works for Chevy will work for Pontiac. So, there should be quite a few cheap ones out there.
I made mine. Used a Pontiac HEI housing, and a Chevy HEI shaft.
Takes a nice strong 1/2" drill to turn it fast. Had a good one, but it quit going counterclockwise. Bought a cheap one from Harbor Freight. It works, but just barely. Thought it might burn up, but it didn't. Got the job done.
Here's a couple of name brand models. Should be lots of cheaper Chinese made models out there, especially on Ebay.
https://www.summitracing.com/parts/mor-62200/overview/
https://www.amazon.com/Moroso-62200-Pump-Primer-Chevy/dp/B000COU27K
https://www.summitracing.com/parts/mrg-3795g/overview/make/pontiac
Here's a no name on Ebay, for $15.99 shipped. As usual, Ebay links don't work on THIS site. They work on every other forum & FB page I use. Anybody know why they won't work on this particular site ???
https://www.ebay.com/itm/Oil-Pump-Primer-SBC-Chevy-V8-OIL-PRIMER-TOOL-FREE-SHIPPING-IMCA-USMTS-UMP-DRAG/223439007840?hash=item340600b060:g:kLcAAOSw-1ZcgTXD
I made one out of one of those cheap Chinese HEIs I was running in my 428 until it started to fall apart. Before that I used a 1/4" rod that I flattened one end of in my bench vise. I spun it with a 1/2" cordless drill.Had to be careful but worked.
