M Offline
I have a 67 convertible in process of restoring. I am going to put on 15 inch rallys. Does anyone know what tire size will fit comfortably all around? I am not going to do any body mods.
Thanks so much
Mark
U
U Offline
Are you trying to get as wide as you can? Usually that is what folks are asking. I have 225x60 BFG Radial TAs on 15x6 Rally IIs. Not super wide at all but good solid look. Drive good. Zero worries.
J Offline
thanks good info want a bit better look and better rear grip than stock while keeping the original look[b][/b]
215-65-15's. I had them on my 67 for a while. There was a little rubbing with a passenger when I hit a dip. My friend has the same size on his 67 bird and never had a problem. I've got those wheels/tires on my 69 goat now and went back to 14's on the bird.
I used to run 245/50/14 BFG on 7" rally's. It was a squeeze but they went on. Shortest sidewall I could find. No rubbing but I had to drop the car because they looked so tiny in the wheel opening.
M Offline
Just looking to see what width will fit comfortably on front and back and also the height. 15s give more options for tires. Want to put a wider tire on than stock. Not looking to put a big wheel/short tire or lower car.
Build has a long way to go. I am working on the rear section, everything out there. Rebuilding the rear end and need to decide on gears. Want to put a gear vendors overdrive on my Muncie 4 speed and tire size factors in on what highway RPMs I will get.
Thanks
67 HO convertible,4 sp, factory AC.
Mark
W Offline
I've got 225/60 15s redlines from Diamondback on 15x7s on my convertible.
New Member
New Member
Thanks for all the replies. Gives me an idea of tire sizes and what highway RPM's I will get.
67 HO convert, 4 sp, factory AC, mariner turquoise with matching interior.
78 anniversary corvette
I just replace mine last year,the car came with 235-60-15. They rub a little on the upper inside wheel well when turning left an hitting
a bump. Other than that I need to replace the shocks on the front, just find a tire dealer that can put a good balance on them.
Posts298,897
1 members (Dennis in Indiana), 161 guests, and 25 robots.
JFF 1
