Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Need to replace my chewed up yoke. I've searched and searched and can't find the correct replacement yoke. All the ones that were close are about 1/2 inch too long. And most of them have the external clips and not the inside clips. I installed one of those and I only have 3/8" pull out from the back of the trans which makes me nervous. Word on the street is that you need about 3/4-1 inch pull out. The only one I could find that is dimensionally correct is Spicer 2-3-4911X except it has the external clips. So I ordered that one from Summit and it is on back order. I also ordered a spicer 5-3022-1X combo u joint to use it with my stock drive shaft. https://www.summitracing.com/parts/sdh-2-3-4911xhttps://www.summitracing.com/parts/sdh-5-3022-1xAnybody know where I can get a new dimensionally correct muncie trans yoke? It needs to be about 5 inches to the centers of the u joint cups and use the GM 3R series U joint.
Yoke
Pull out
Posts: 611 Likes: 3
Posts: 611 Likes: 3 |
Thanks, Dennis
Thanks. That’s the one I’ve got on there now. It’s 5.5 inches to the center of the u joint cups. I need about 5 inches.
Posts: 611 Likes: 3
Thanks, Dennis
That’s the one I ordered from Summit along with a combo u joint. Hopefully that will work out or else I will shorten the driveshaft by 1/2”
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
I can’t help with your yoke issue but I was wondering what that elect box/switch thing is that is on the shifter bracket in your picture? Backup light switch?
Yes, backup light switch mounted on my aftermarket hurst shifter. The car was set up that way when I got it.
I ended up getting a high end ($200+) yoke from Denny’s. The spicer one from summit is on permanent back order. I got the last one of these.
2,192
74
