Posts: 9,027 |
Just getting ready to bolt my freshly painted subframe on and forgot which way the brace goes on. There is a "scallop" or "dimple" on one side, does it go to the front or back??
Any one know or have a correct picture??
"shoulda taken a photo of that one too"
Posts: 33 |
I never notice a dimple or scallop. I've had mine off and on several times, goes on either way. The holes are in the same place no matter how you put it on.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Here's some shots of mine. Mine's a 67 so it has holes for the factory shifter mounting. That's how I figured out how to orient it. Maybe it doesn't matter, as Sanford says. ![[Linked Image]](http://i32.photobucket.com/albums/d9/strugar/PICT3256.jpg)
Posts: 5,139 |
Glad to see my M-20 isn't the only one out there "seeping" a bit! If it was dry under there I'd be concerned!
I think that's motor oil, Nash. Hopefully the tranny is water tight. If the tranny is orange, does that mean it started life in a Chebby?
Posts: 9,027 |
Well mine does!, and it looks like it was meant to be there but I knoe there is nothing that would "nestle" down in the dimple.
I did decide to put it in as I noticed some scrape marks on one side of the crossmember so figured that must be the front!
207
