#7157 03/24/03 03:50 PM
OK we are talking about mono-leaf springs.
been seeing in alot of different catalog were you can convert a mono-leaf rear end to a multi-leaf, i need new springs anyway. so here go's
1 Has anyone tried these conversion kit on a mono rear-end?
2 Did it work/ Did it hold up? ( will be hooked up to 400/400 w/shift kit and 2000 stall)
3 Who is a good supplier ( quaility parts a must )
thanks in advance jerry
this is for a 67 FB conv. 400/400 with a GM posi rear end w/ MONO ( for now )
" almost done......and way-past broke $$$$$
sure baby....just a couple more items and i'm done.
http://firstgenfirebird.org/show/closeup.mv?CarID=714
#7158 03/24/03 04:17 PM
Q
Q Offline
Eaton Springs (Detroit) are the best springs. They will tailor-make any spring you need and they will fit the car perfectly. You will need different mounting hardware over the axle. I believe the perches are the same, but one of the others will know for sure.
Q
#7159 03/25/03 10:42 PM
thanks for the info "Q"
OK but has anybody out there done this to their FB yet?
i dont want to do all of this and find out later that it want hold up
to heavy foot take-offs! laugh laugh laugh
or do i stick with the mono and add track bars? :rolleyes:
thanks again jerry
#7160 03/26/03 12:41 AM
I changed from mono to mulit leafs on my 67 bird a while ago. The perches are different. I had a spacer made so I wouldn't have to change my perches. Wasn't exactly proper and made locating the sprongs a pain. I'd check into putting the correct perches on your rearend.Just my .02.
Honest dad, that 455 on the side of the block is a serial number smile
#7161 03/26/03 03:44 PM
T Offline
I have a '68 rearend housing that has the perches still on it I would give you if you pick up or pay shipping. Would need to be cut off & welded on your rearend.
Steve wink
#7162 03/26/03 04:44 PM
K
K Offline
I have been looking at doing this myself. A couple of options not mentioned were the 3-leaf mono replacement springs. JCWhitneys and others carry them. Upgrading to an 8.5 rear-end out of a 73-79 Nova is an option as well, stronger, parts cheaper and same width. Besides the springs, is changing to the different shock mounting location from 67 to 68 & later..
#7163 03/26/03 08:37 PM
Antibiotics... laugh
Si Vis Pacem Parabellum
1968 Alpine Blue 400 4 speed
#7164 03/27/03 04:42 PM
I was waiting for that answer Tom... should have known... either you, Quenton or Bjorn....
I'd got with Q's suggestion, have a replacement set made by Eaton, and you'll be almost as good as multi leaf, but better than new! And no pearch problems...
that seems like the easiest way out.
Brett - 67 Drop Top 455!
[Linked Image]
#7165 03/27/03 06:43 PM
Q
Q Offline
I restrained myself ...
"Penicilin ... for the man who has everything!"
Q
#7166 03/27/03 10:33 PM
It was hard ,but I could restrain myself...
ME, Brett? ME? how could you think such....lol
:p Bjorn
Topics35,545
Posts298,893
0 members (), 87 guests, and 20 robots.
