Anyone try this combo? Will it fit? Thanks! Dave
1967 original 326 Coupe (my 12 year old son's)
1968 400 Coupe - 467 stroker (mine)
1968 Sprint 6 4-speed convertible
1982 K5 Blazer
2008 GMC CC 2500 Z71 Duramax programmed and piped
2009 Nissan Murano (wife's)
Yes, have one on a '68 400 right now.
If you have a flat hood, beware of clearance, it's a TALL manifold.
Vikki
Restoration Gallery
http://thefirstgensite.com
it will also fit with a 400 hood. I have this same combo
Aaron
I have the 400 hood. So the HEi distributor will clear the intake OK? What type of air cleaner did you have to go with? Will the basic round aftermarket sandwich type work? Thanks! Dave
1982 K5 Blazer
yes, aftermarket round open element
Vikki
Restoration Gallery
I cannot answer with certainty that your HEI will fit because I have the MSD ready to run which I believe is a bit smaller.
But the MSD fits beautifully. I have the 3 inch regular sandwich type air cleaner. I have not permanently mounted the air cleaner since I am still working on the engine but during mock up the hood closed without hitting. I was lucky because i have open hood scoops, I was able to watch the hood go down to check if everything would fit.
Aaron
Hei fits fine with RPM intake.
Check my picture post. There may be a shot of it.
If not, will take one.
Need to upload more pic's this weekend any way.
Have a 14" dia with a 1.5" drop base(cheapy) a/clnr.
Still have 1/4"-1/2" clearance to hood.
My car hates me...
Forgot, a/clnr element is standard 3".
My car hates me...
Also forgot, have a 1/2" n2o plate and 850 demon.
My car hates me...
ok, quick update. I fit the air cleaner on the carb last night after I set up the throttle linkages. The air cleaner that I have (14" drop base) clears the hood but will not work with a Holley 750 DP. The throttle arm on the carb hits the base of the air cleaner. I may try a 3/4 spacer and a 2" filter element. I will update when I figure it out.
Aaron
Rotate the air cleaner so that the indentation for the breather tube is in the throttle arm area. You may still need a small spacer.
Vikki
Restoration Gallery
N
N Offline
Or "create" an indent like Vikki points out, if your lower assembly pan is a generic brand. You can modify one of those to work fine. Just a bit of hammer tapping and alignment.
Thanks for the help guys! Got the engine and tranny bolted in yesterday. getting ready to be putting a lot of hours in at work for a few weeks so it's on hold for now. When I get back to it I'll post up. Thanks again! dave
1982 K5 Blazer
Quick update:
The 14" round air filter with 3" element DOES fit. You must get a dropped base however. My throttle return springs and spring bracket were hitting the base and not allowing full throttle arm movement. I just flipped the spring bracket and everything is great. Dave, you will find that the stock throttle bracket will not work without modifying it. I used this http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_86840_-1 and it works great. You just need to change the springs because the ones that come with it are way too strong. Hope this helps
Aaron
0 members (), 138 guests, and 25 robots.
