#223397 03/20/11 04:18 PM
Question? On a fresh 350 what should the oil pressure be at hot idle 800 rpm in drive?
SYN 10W30.
Cheers
Randy
Hey Randy how are you,remember we met last summer when you were out for a drive and spotted my bird at my parents place.For what its worth my 350 runs around 35-40 psi at idle with a mellings oil pump 20w50 brad penn oil.
Harry 69 Firebird
_________________________________________________
1969 firebird 350/auto
2012 mustang v6 (wifes car)
2012 jeep compass (winter vehicle)
2008 dodge ram 4x4 Hemi
I have read that all that is required is 10 lbs per thousand RPM..not sure if thats true.
M Offline
Generally speaking, the "rule of thmb" of 10 lbs. per 1,000 RPM is okay, but not "in stone". Many small block run only 45-50 lbs., but rev well beyond 7,000.
At a "hot idle, in gear", one should have at least 20 lbs. It should "jump" to 60 lbs., before it reaches 2,000.
How fresh is the motor, I would not run synthetic untill it is well broken in. Also synthetic will show less pressure, but more volume.
