Posts: 2 |
Question? On a fresh 350 what should the oil pressure be at hot idle 800 rpm in drive? SYN 10W30.
Cheers Randy
Posts: 1,458 |
Hey Randy how are you,remember we met last summer when you were out for a drive and spotted my bird at my parents place.For what its worth my 350 runs around 35-40 psi at idle with a mellings oil pump 20w50 brad penn oil.
Posts: 3,615 |
I have read that all that is required is 10 lbs per thousand RPM..not sure if thats true.
Posts: 215 |
Generally speaking, the "rule of thmb" of 10 lbs. per 1,000 RPM is okay, but not "in stone". Many small block run only 45-50 lbs., but rev well beyond 7,000.
At a "hot idle, in gear", one should have at least 20 lbs. It should "jump" to 60 lbs., before it reaches 2,000.
Posts: 312 |
How fresh is the motor, I would not run synthetic untill it is well broken in. Also synthetic will show less pressure, but more volume.
Posts298,897
142
