#285533 03/06/14 09:46 AM
C
C Offline
What do u have for fuel lines ....
Cali1969 #285535 03/06/14 12:18 PM
Steel from inline tube.
Cali1969 #285537 03/06/14 12:43 PM
Dual steel lines from inline tube also.
Keith
68 Bird
428 Auto.
Cali1969 #285538 03/06/14 01:09 PM
Fine Lines is another source.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Cali1969 #285539 03/06/14 01:09 PM
Main Fuel Line Tank to Pump 2pc, 3/8" Standard OEM Spec Steel
Fuel Return Line Tank to Pump 1/4" Standard OEM Spec Steel
Cali1969 #285556 03/06/14 04:37 PM
Those are outside tube measurements. (just to be clear)
HaroldB #285558 03/06/14 04:43 PM
Not for a 350 or cammer tho...
68tpls400 #285561 03/06/14 04:48 PM
hey he just asked What do u have for fuel lines .... grin
HaroldB #285562 03/06/14 04:51 PM
Ah, that is true... Just didn't want him running out to buy something that may be incorrect for his car. Sorry!
Cali1969 #285573 03/06/14 07:22 PM
Stainless steel lines from inline tube.
Cali1969 #285581 03/06/14 08:58 PM
Speaking of fuel lines...i just recently added a return and ran it over the top of the crossmember on the pass side in the engine bay. Well when I dropped the engine back in and bolted the headers up, well guess what? The #2 header pipe sat pretty much right on top of the return line. Let me tell you there wasn't a whole lot of wiggle room after eveything was installed. I was able to bend it out of the way some but I would've run it much closer along to the frame horns that hold the upper control arms if I had known there was going to be an issue. Just by way of information in the event anyone else is planning to install the same.
Cali1969 #285589 03/06/14 09:15 PM
C
C Offline
Stainless or oem??? Are stainless much better since therre a bit more
Cali1969 #285590 03/06/14 09:26 PM
I would say they are better but I thought....the steele lasted 45 years. So the new ones will out last me.
HaroldB #285592 03/06/14 09:40 PM
Agree. No winters (or even rain for that matter) for me. Steel will last just fine.
And the best part... that's factory! grin
Cali1969 #285593 03/06/14 09:45 PM
Trouble with stainless is it can be very tough to flare the ends.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
Cali1969 #285645 03/08/14 01:24 AM
4 Offline
I have an A/C car that has a return line too. It was original 350 2bbl.
Cali1969 #285648 03/08/14 01:35 AM
I am using steel, I plan to spray them with Eastwood satin clear to protect them
Gordy
1968 Firebird 400 4 Speed
68FB400
68tpls400 #285654 03/08/14 04:45 AM
68/69 Sprints are 5/16th's / 1/4
69 OHC ZH Sprint Hurst 3 Speed 3:55
OHC Forum http://sohcsix.yuku.com/
WANTED: 1969 OHC Sprint "H" Camshaft
68tpls400 #285775 03/11/14 09:06 AM
C
C Offline
What size fuel lines would be good im planning to drop a pontiac 461..
