Posts: 245 |
What do u have for fuel lines ....
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
Posts: 442 |
Dual steel lines from inline tube also.
Keith 68 Bird 428 Auto.
Posts: 7,719 |
Fine Lines is another source.
Posts: 3,220 |
Main Fuel Line Tank to Pump 2pc, 3/8" Standard OEM Spec Steel Fuel Return Line Tank to Pump 1/4" Standard OEM Spec Steel
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
Those are outside tube measurements. (just to be clear)
Not for a 350 or cammer tho...
Posts: 3,220 |
hey he just asked What do u have for fuel lines ....
hey he just asked What do u have for fuel lines .... Ah, that is true... Just didn't want him running out to buy something that may be incorrect for his car. Sorry!
Posts: 1,394 Likes: 2
Posts: 1,394 Likes: 2 |
Stainless steel lines from inline tube.
Speaking of fuel lines...i just recently added a return and ran it over the top of the crossmember on the pass side in the engine bay. Well when I dropped the engine back in and bolted the headers up, well guess what? The #2 header pipe sat pretty much right on top of the return line. Let me tell you there wasn't a whole lot of wiggle room after eveything was installed. I was able to bend it out of the way some but I would've run it much closer along to the frame horns that hold the upper control arms if I had known there was going to be an issue. Just by way of information in the event anyone else is planning to install the same.
Posts: 245 |
Stainless or oem??? Are stainless much better since therre a bit more
Posts: 3,220 |
I would say they are better but I thought....the steele lasted 45 years. So the new ones will out last me.
I would say they are better but I thought....the steele lasted 45 years. So the new ones will out last me. Agree. No winters (or even rain for that matter) for me. Steel will last just fine. And the best part... that's factory!
Posts: 6,758 |
Trouble with stainless is it can be very tough to flare the ends.
Posts: 1,770 |
I have an A/C car that has a return line too. It was original 350 2bbl.
Posts: 395 |
I am using steel, I plan to spray them with Eastwood satin clear to protect them Gordy
1968 Firebird 400 4 Speed 68FB400
Posts: 1,015 |
Not for a 350 or cammer tho... 68/69 Sprints are 5/16th's / 1/4
Posts: 245 |
What size fuel lines would be good im planning to drop a pontiac 461..
2 members (Geoff, Jimc2002),
469
119
