Posts: 29 |
I have a new (to me) 68 non-AC car with Vintage Air. Running hot. Radiator good. Just changed out to larger fan, 180 thermostat and higher output AC rated water pump. Plus has electric fan in front of AC condenser (which was running backward, but now corrected and connected to ignition so always on). Now better, 180-190 while driving, but quickly gets to 205-210 when idling in hot weather. Does not have any of the baffles and I suspect adding them is my next best bet to help. I understand the upper filler panels and lower valence, but not the masticated filler panels. Despite the great pics in this post ( https://firstgenfirebird.org/forums/ubbthreads.php?ubb=showflat&Number=230387), I am disoriented without obvious external landmarks. Do the filler panels go on the sides of the radiator? What gap are they filling and what exactly do they attach to? The repro upper panel comes with fasteners. What about the lower valence and masticated panels? What bolts or clips do I use? One post mentions Chrysler headliner clips??? Can't I just use short bolts with flat folded sheetmetal nuts? I have a double pulley for water pump and fan, 8" diameter. Should that be smaller and worth changing compared to everything else? Unrelated question if someone has input. The car runs fine EXCEPT the engine occasionally stutters/coughs and dies, usually when hot and drive after has been idling a while or after has been off for a short period and start to drive again. Thanks David
Posts: 2,113 Likes: 1
Posts: 2,113 Likes: 1 |
Ibut not the masticated filler panels. Despite the great pics in this post ( https://firstgenfirebird.org/forums/ubbthreads.php?ubb=showflat&Number=230387), I am disoriented without obvious external landmarks. Do the filler panels go on the sides of the radiator? What gap are they filling and what exactly do they attach to? The repro upper panel comes with fasteners. What about the lower valence and masticated panels? What bolts or clips do I use? One post mentions Chrysler headliner clips??? Can't I just use short bolts with flat folded sheetmetal nuts? The lower valence will need bolts to hold it on, I don't remember size. By masticated filler panels, are we really talking about these: http://www.classicindustries.com/product/firebird/parts/k282.html
Posts: 29 |
I think I am just talking about these, but not exactly sure: (not the splash/mud guards on inner fender wells, but just the air baffles for radiator) https://www.npdlink.com/store/products/C_8155_202A-118386-1819.htmlDo they go on each side of the compartment in front of radiator (with the other baffles/valence on top and bottom)? Is my $300 better spent on all these air baffles or instead upgrading to a bigger aluminum radiator (I have stock repro now)? Thanks
Posts: 6,160 Likes: 51
Posts: 6,160 Likes: 51 |
Jim '68 400HO Conv.
Posts: 29 |
when I try to duplicate view and photo of the masticated filler panels in the above referenced post, I see this: (not sure if my picture posted) I seem to have metal filling the gap between rad and sidewall, where other pic shows the filler panel ???
THE BIG QUESTION AT THIS POINT: BETTER TO SPEND $300 ON THE UPPER BAFFLES AND LOWER VALENCE OR PUT TOWARDS ALUMINUM RADIATOR UPGRADE?
Posts: 3,220 |
Maybe the '69 is different than the '68.
Jim '68 400HO Conv.
Posts: 29 |
Thanks Harold. You don't seem to have the lower black valence in place in your photos??? Seems you are using the flexible filler panels both at bottom and sides of the cavity in front of rad. See the pics in the post prior to your reply. Very confusing.
Posts: 29 |
mine is a 68 (despite forum ID from when I had a 69) I don't seem to need the flexible filler panels, just the upper baffles and lower valence still trying to decide if better to do than aluminum radiator upgrade instead
Posts: 29 |
my water pump/fan double pulley is 8" diameter should I have smaller? important? still deciding priority order of next investment: upper baffles/lower valence or aluminum radiator or smaller pulley or other fixes
any thoughts appreciated
Posts: 3,220 |
Thanks Harold. You don't seem to have the lower black valence in place in your photos??? Seems you are using the flexible filler panels both at bottom and sides of the cavity in front of rad. See the pics in the post prior to your reply. Very confusing. Some of the pics I have the lower baffle and a couple I don't. I Only have flexible fillers on sides not at bottom. In this picture in the service manual, lower right shows the seals Jim and I have in place. The metal you see in your picture in the bumper support bracket. These seals attaches to it and the radiator core so there is no open gap in in the corner you see. So all all goes through the radiator instead of forced through the open gaps.
Posts: 29 |
perfect, that diagram really helps, thanks
Posts: 20,054 |
other things could make it run 'hot' too, like if its running too lean....and is timing set right?
Posts: 29 |
timing checked, I don't think running lean have ordered baffles and am looking to switch from 8" to 6.5" pulley hopefully that will do, since problem at idle
Posts: 105 |
Have you checked the water pump divider plate? It's behind the water pump on the timing cover. Aftermarket water pumps seem to have smaller impellors than the factory originals, and the space between the water pump impellors and backing plate gets too large and there isn't good suction at idle to move the coolant around. You can take the water pump off and hammer the divider plate so it sits pretty close to the water pump and it will make you car run a lot cooler. This is if you haven't already done so.
My car always ran hot and I couldn't figure it out. Then I finally saw something on here or in one of Jim Hands books and I finally changed the clearance. Runs super steady now. No more over heating and/or vapor lock.
Also depending on the carb, some pull vacuum advance from the ported vacuum port vs. the manifold vacuum port. If you run it off the ported vacuum port you won't have any advance at idle and it will essentially make your car run with less timing and therefore more heat.
Posts: 105 |
Posts: 29 |
OK, added AC baffles, new smaller fan/water pump pulley, new fan, high output water pump and thermostat. AT, vintage AC, 350/350 car still running hot in NC. Time for an aluminum radiator upgrade. Which one best? Is something like this from Classic Industries a significant enough upgrade? I assume 4 row is their best. A8600112 - 1967-69 GM F-BODY - ALUMINUM RADIATOR (4 ROW) - 17" X 23" X 2-34" CORE Or is a specialty radiator best, like Desert Cooler, etc. I have read in other forums (esp. for hot rods) that 1.25" tubing is the best. Any recommendations for a radiator to never run hot again??? Thanks!
Posts: 3,220 |
Is reaching 210 degrees really that hot at idle with cast iron heads and block? Pontiac did not have the dummy light come on till around 245 I think.
A lot can depend on the engine build and timing.
Posts: 29 |
OK, so maybe half my problem is that I have a temp gauge gets up to around 210 on hot day, maybe 215 when turn off engine gauge quickly moves to over 230 which I assume is normal as will just as quickly edge down when turn on engine if those more knowledgable than me think 210-215 is OK for engine than maybe I will live with it for now would still be interested in any alumuminum radiator recommendations (more in the $300-$400 range than the $800+ range)
Posts: 3,220 |
So I went back and checked the service manual. Pontiac used a 190 degree thermostat. It states that it should fully open not to excess 222 F. The boiling point is 258 F with a 15 PSI cap. Most things I've read is operating temperature swing 190-220F. I rechecked the dummy light setting and read it is around 245F.
Posts: 29 |
Thanks Harold. Sounds like these old iron 350s can safely run at 220 degrees or less, which makes me feel a whole lot better about driving it and turning on the AC,
Topics35,545
Posts298,891
1 members (miltonf),
77
