O
New Member
New Member
O Offline
Hi guys,
I'm new to the forum and will introduce myself under separate cover shortly. I recently acquired a '67 Firebird and am real excited about it. It was a great runner, but the motor spun a bearing in the spring and I took the opportunity to put a 461 stroker in it. The challenge I'm facing however is that the taller valve covers, which are needed to clear the roller rocker girdles, are in the way of me installing my wiper motor.
I'd prefer not to do much fabrication on the firewall as the car is painted, albeit not show quality, and would appreciate any insights from this forum. Has anyone faced this before? Is there an alternative approach that's been used?
Thanks,
Joe
I'm not sure how tall your tall valve covers are, but I have a set of tall Moroso chrome valve-covers on mine, and while its a complete PITA to get the driver's side on and off, it does fit with some patience.
1967 Firebird 400/4spd all numbers matching
1971 Camaro Pro ET Drag Car
1970 Camaro real Z-28 (needs everything)
1963 Impala 409 dual quad 4 spd
2003 Victory Vegas
2009 Pontiac G8 GT
(My wife says I have a problem.....)
O
New Member
New Member
O Offline
Thanks for your feedback on it.
It was at the end of my 2nd 18 hour day working on the car when I made the decision that they didn't fit, so maybe i need to revisit that again. I also have tall Morosos.
Here's a pic:
https://mustaribrand.files.wordpress.com/2015/06/photo.jpg?w=1145
It should fit, but will be tight.
I believe Detroit Speed makes a smaller, modern wiper motor that fits FGF's
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
1980 Turbo Trans Am
NPD lists that same part in their catalog as well, since Detroit Speed is out-of-stock.
-=>Lee<=-
U
U Offline
Has anyone here used one of those wiper motor kits? Curious, if the switch mounts in the existing wiper switch location without looking to messed up??? Also, not trying to change the subject here, but almost looks like you will also have a hood clearence problem if you have a sotck hood, unless you use a drop base air filter.
O
New Member
New Member
O Offline
Thanks for the feedback, guys.
Yeah, that solution looks awesome, but I'm not really that stoked about spending $550 on a wiper motor if I can help it.
I did find this thread about someone throwing an '89 blazer wiper motor in their first gen Camaro. Maybe this could be an alternate path?
http://www.camaros.net/forums/showthread.php?t=127854
Cant remember where, but saw either an article or post on Performance Years how someone re-clocked his for clearance.
My car hates me...
JFF 1
