New Member
New Member
Posts: 4 |
Hi guys,
I'm new to the forum and will introduce myself under separate cover shortly. I recently acquired a '67 Firebird and am real excited about it. It was a great runner, but the motor spun a bearing in the spring and I took the opportunity to put a 461 stroker in it. The challenge I'm facing however is that the taller valve covers, which are needed to clear the roller rocker girdles, are in the way of me installing my wiper motor.
I'd prefer not to do much fabrication on the firewall as the car is painted, albeit not show quality, and would appreciate any insights from this forum. Has anyone faced this before? Is there an alternative approach that's been used?
Thanks,
Joe
Posts: 93 |
I'm not sure how tall your tall valve covers are, but I have a set of tall Moroso chrome valve-covers on mine, and while its a complete PITA to get the driver's side on and off, it does fit with some patience.
New Member
New Member
Posts: 4 |
Thanks for your feedback on it. It was at the end of my 2nd 18 hour day working on the car when I made the decision that they didn't fit, so maybe i need to revisit that again. I also have tall Morosos. Here's a pic: https://mustaribrand.files.wordpress.com/2015/06/photo.jpg?w=1145
Posts: 1,394 Likes: 2
Posts: 1,394 Likes: 2 |
It should fit, but will be tight.
Posts: 7,719 |
I believe Detroit Speed makes a smaller, modern wiper motor that fits FGF's
Posts: 7,719 |
Posts: 1,923 |
NPD lists that same part in their catalog as well, since Detroit Speed is out-of-stock.
Posts: 1,202 Likes: 1
Posts: 1,202 Likes: 1 |
Has anyone here used one of those wiper motor kits? Curious, if the switch mounts in the existing wiper switch location without looking to messed up??? Also, not trying to change the subject here, but almost looks like you will also have a hood clearence problem if you have a sotck hood, unless you use a drop base air filter.
New Member
New Member
Posts: 4 |
Thanks for the feedback, guys. Yeah, that solution looks awesome, but I'm not really that stoked about spending $550 on a wiper motor if I can help it. I did find this thread about someone throwing an '89 blazer wiper motor in their first gen Camaro. Maybe this could be an alternate path? http://www.camaros.net/forums/showthread.php?t=127854
Posts: 5,108 |
Cant remember where, but saw either an article or post on Performance Years how someone re-clocked his for clearance.
138
