#327530 08/16/20 05:21 PM
A
A Offline
Any estimate on the value of a 68 400 HO Ram Air 4 spd that is supposedly PHS documented?
Have you seen the PHS documentation? '68 400 HO Ram Air??
What is the engine code?
'68 400HO Conv.
A
A Offline
No I haven't seen the PHS documentation or verified the engine code. I was just trying to get an idea of what the car would be worth if what the ad says is legitimate.
Yes the ad says it is a 68 400 HO Ram Air car.
A
A Offline
Pictures
In '68 there was the 400, 400HO, 400 RA1, and 400RA2 engines but not a 400HO RA. That's why I would want to see the PHS and engine code to see what it is.
'68 400HO Conv.
With all the incorrect parts on that car, I would question if it is even a real 400 model.
Well it says Ram Air on the air cleaner. I have a 67 Ram Air convertible. It's one of none.
One of none!... Well that is rare!!! laugh
I factory correct sticker!!! It's gotta be laaagit.
What's it worth? $30-$150k
Gus68 #327550 08/17/20 05:35 PM
I think you need to stick to French!
laugh
laugh
My frog is much worse!
Gus68 #327555 08/17/20 10:22 PM
A
A Offline
My question was how much would the car be worth if it checked out not how to verify its authenticity but thanks for your "help".
Since there is no such thing as an HO Ram Air as Jim pointed out then it cannot be verified and we provided sufficient “help”
Actually apc45039, we are trying to help you.
'68 400HO Conv.
It's probably intended to be a 68 FB 400 HO
Here is a valuation from Haggerty:
NOTE: Prices in CND Dollars
For example: $73,600 CND = $55,650 US
Attached PDF document
Gus68 #327573 08/19/20 11:20 AM
Apc, you’ll find a lot of people don’t know what they are talking about when it comes to these cars. For instance a lot of people will tell you that it’s a ram aim car just because it has hood scoops. I suppose they will do it to up sell the car but valuation is directly related to the car’s pedigree, so to speak. Apparently the seller doesn’t know if he is trying to sell an Apple or an orange. Buyer beware.
Well worded!
W Offline
So, a Warren County boy? There will be enough locals in the Cinncinati area who can help with identification as well as an opinion on value by looking at the vehicle in person. At this board, given the ad has identified it as something that was never produced at a GM factory, we cannot do so. Heck, is Paul Freese still in business in Batesville? He's more of a GTO guy, but he'll have an opinion.
T Offline
Here are correct engine codes for 1968 Firebird with 400 engine:
WZ- 400 MT
YT- 400AT
WQ- 400HO MT
YW- 400HO AT
WI- RA I MT (D port head)
XN- RA i AT (D port head)
WU- RA II MT (Round port head)
XT- RA II AT (Round port head)
Engine codes are stamped on passenger side of block around timing cover. Block casting # is on back side of block passenger side along transmission, hope this helps.
N
N Offline
It could have been modified and enhanced to the point where it does indeed qualify as a RAM-AIR, but certainly not an original build from the factory. Go check it out!
