No, I filled it in with clear coat( any kind of model clear will work). When you fill the red and black, leave some room so that you can put the clear in. i filled the clear all the way to the rim. the emblems are made so that the ends are all higher the the middle,this way you can fill the clear all the way up to cover everything
