To make it a little more simple... where ever you have #1 on the cap will not matter for start up. Just as long as you have the rotor pointing at it when the timing mark comes up on compression stroke. I think the advice you are confused about was leading you to get #1 in the stock position(from the factory). This is great for uniformity but it's not a must for the engine to run correctly.
