Again, you put too much weight on the hood. The engine is the 'meat' of the ram air. You are thinking too literally with 'ram air'. Ram air is an engine option, not a hood option. That's just 611(hood and pans)
No. They are two separate entities. RA the engine and RA the hood. Other than T/A, every 348 and 347 could be ordered with 611 or not ordered with 611. That means they are separate (related, but still separate) and combining them or ignoring that fact just adds to the confusion.
Originally Posted By Fbody69
Originally Posted By Kurt S
Also, the definition of insanity is doing the same thing again and again and expecting a different result. I guess we're insane cause Jim isn't going to change his mind on this and he's insane cause he keeps posting the same pictures over again.
Kurt, You really should stick to your IQ because your EQ is lacking. I've not stooped to your level of personal attack. I expect the same from you...thanks.
Reread that. It was not intended as a personal attack. I poked fun at us for saying the same things to you and you for posting the same pics 4 more times. Obviously this discussion is going nowhere at this point.
