Rating: 5
Thanks to both of you--fantastic pictures and info! I've attached a picture of the First Generation heater hose nipple for the passenger-side head. Note there is a spiral restrictor inside to limit flow to the heater core.
I've replaced many heater cores in early GTO's due to lack of restriction in the heater coolant feed line (the small hose). I don't want to take off the RF fender on this Firebird to replace a heater core any time soon. If needed, I'll use the same idea we use on early GTO's--a 5/8" diameter cylindrical piece inserted in the hose with a 3/16" hole in the center to limit flow. Meanwhile, I'm going to call Butler to see what they've done with the E-heads.
Also need to figure out where to attach the negative battery terminal to the engine. I hate to remove one of the head bolts to replace with one with a stud to accept the cable, but there may be a better way?
'68 Restoration Questions bocoogto 03/30/15 01:14 AM
Re: '68 Restoration Questions HaroldB 03/30/15 01:34 AM
Re: '68 Restoration Questions bocoogto 03/30/15 02:35 AM
Re: '68 Restoration Questions Dennis in Indiana 03/30/15 04:54 AM
Re: '68 Restoration Questions Jarett 03/30/15 05:53 AM
Re: '68 Restoration Questions salmon38 03/30/15 01:55 PM
Re: '68 Restoration Questions HaroldB 03/30/15 02:49 PM
Re: '68 Restoration Questions salmon38 03/30/15 03:39 PM
Re: '68 Restoration Questions bocoogto 03/31/15 08:38 PM
Re: '68 Restoration Questions HaroldB 03/31/15 09:47 PM
Re: '68 Restoration Questions bocoogto 04/06/15 01:49 AM
Re: '68 Restoration Questions bocoogto 04/06/15 01:52 AM
Re: '68 Restoration Questions HaroldB 04/06/15 03:05 AM
Re: '68 Restoration Questions bocoogto 04/12/15 01:40 AM
Re: '68 Restoration Questions HaroldB 04/12/15 01:42 AM
Re: '68 Restoration Questions bocoogto 04/14/15 01:05 AM
Re: '68 Restoration Questions HaroldB 04/14/15 03:22 AM
Re: '68 Restoration Questions bocoogto 04/15/15 03:48 AM
Re: '68 Restoration Questions bocoogto 05/24/15 09:12 PM
Re: '68 Restoration Questions bocoogto 05/24/15 09:17 PM
Re: '68 Restoration Questions bigchief 05/25/15 05:18 AM
Re: '68 Restoration Questions bocoogto 05/29/15 08:00 PM
Re: '68 Restoration Questions bocoogto 05/30/15 05:47 AM
Re: '68 Restoration Questions dougsoldcars 07/29/15 01:24 AM
Re: '68 Restoration Questions HaroldB 05/30/15 11:56 PM
Re: '68 Restoration Questions bocoogto 05/31/15 02:47 AM
Re: '68 Restoration Questions HaroldB 05/31/15 03:14 PM
Re: '68 Restoration Questions bocoogto 05/31/15 06:09 PM
Re: '68 Restoration Questions JamesM 06/09/15 07:12 PM
Re: '68 Restoration Questions bocoogto 06/12/15 05:55 AM
Re: '68 Restoration Questions JamesM 06/12/15 01:35 PM
Re: '68 Restoration Questions JamesM 06/13/15 05:54 AM
Re: '68 Restoration Questions HaroldB 06/13/15 06:18 AM
Re: '68 Restoration Questions JamesM 06/13/15 02:42 PM
Re: '68 Restoration Questions bocoogto 06/13/15 04:36 PM
Re: '68 Restoration Questions bocoogto 06/14/15 02:59 AM
Re: '68 Restoration Questions bocoogto 06/14/15 05:51 PM
Re: '68 Restoration Questions bocoogto 06/16/15 05:46 AM
Re: '68 Restoration Questions ramair68 06/16/15 06:49 PM
Re: '68 Restoration Questions bocoogto 06/18/15 07:31 PM
Re: '68 Restoration Questions wovenweb 06/16/15 06:39 AM
Re: '68 Restoration Questions 68tpls400 06/16/15 01:54 PM
Re: '68 Restoration Questions Sleddog 06/18/15 08:43 PM
Re: '68 Restoration Questions bocoogto 06/20/15 05:56 AM
Re: '68 Restoration Questions wovenweb 06/20/15 08:20 PM
Re: '68 Restoration Questions bocoogto 06/21/15 01:08 AM
Re: '68 Restoration Questions bocoogto 06/21/15 01:10 AM
Re: '68 Restoration Questions bocoogto 06/22/15 08:02 AM
Re: '68 Restoration Questions wovenweb 06/22/15 12:48 PM
Re: '68 Restoration Questions bocoogto 07/02/15 07:16 AM
Re: '68 Restoration Questions HaroldB 07/02/15 06:28 PM
Re: '68 Restoration Questions salmon38 07/02/15 07:18 PM
Re: '68 Restoration Questions bocoogto 07/02/15 10:05 PM
Re: '68 Restoration Questions HaroldB 07/02/15 10:33 PM
Re: '68 Restoration Questions bocoogto 07/03/15 04:53 AM
Re: '68 Restoration Questions HaroldB 07/03/15 05:17 AM
Re: '68 Restoration Questions bocoogto 07/05/15 05:12 AM
Re: '68 Restoration Questions HaroldB 07/05/15 01:23 PM
Re: '68 Restoration Questions bocoogto 07/05/15 04:47 PM
Re: '68 Restoration Questions Jimc2002 07/05/15 07:14 PM
Re: '68 Restoration Questions Gus68 10/11/15 04:10 PM
Re: '68 Restoration Questions bocoogto 10/12/15 03:48 AM
Re: '68 Restoration Questions bocoogto 10/15/15 05:02 AM
Re: '68 Restoration Questions bocoogto 10/17/15 07:51 PM
Re: '68 Restoration Questions bocoogto 07/05/15 09:17 PM
Re: '68 Restoration Questions HaroldB 07/06/15 12:34 AM
Re: '68 Restoration Questions bocoogto 07/06/15 07:30 PM
Re: '68 Restoration Questions bocoogto 07/06/15 09:31 PM
Re: '68 Restoration Questions HaroldB 07/06/15 09:57 PM
Re: '68 Restoration Questions 68tpls400 07/06/15 10:18 PM
Re: '68 Restoration Questions bocoogto 07/06/15 10:58 PM
Re: '68 Restoration Questions bocoogto 07/12/15 05:44 PM
Re: '68 Restoration Questions bocoogto 07/13/15 04:14 AM
Re: '68 Restoration Questions bocoogto 07/19/15 07:30 AM
Re: '68 Restoration Questions bocoogto 07/28/15 06:13 AM
Re: '68 Restoration Questions HaroldB 07/28/15 03:05 PM
Re: '68 Restoration Questions bocoogto 07/29/15 07:18 AM
Re: '68 Restoration Questions Region Warrior 07/29/15 06:48 PM
Re: '68 Restoration Questions bocoogto 07/30/15 04:04 AM
Re: '68 Restoration Questions bocoogto 07/30/15 11:54 PM
Re: '68 Restoration Questions Mushroombert 07/31/15 04:53 AM
Re: '68 Restoration Questions bocoogto 07/31/15 06:29 PM
Re: '68 Restoration Questions bocoogto 07/31/15 06:36 PM
Re: '68 Restoration Questions bocoogto 08/02/15 04:04 AM
Re: '68 Restoration Questions bocoogto 08/02/15 06:30 PM
Re: '68 Restoration Questions Jimc2002 08/02/15 07:58 PM
Re: '68 Restoration Questions bocoogto 08/04/15 01:53 AM
Re: '68 Restoration Questions bocoogto 08/12/15 03:57 AM
Re: '68 Restoration Questions HaroldB 08/23/15 01:36 AM
Re: '68 Restoration Questions bocoogto 08/23/15 07:13 PM
Re: '68 Restoration Questions bocoogto 08/15/15 12:10 AM
Re: '68 Restoration Questions bocoogto 08/18/15 02:51 AM
Re: '68 Restoration Questions bocoogto 08/18/15 05:05 PM
Re: '68 Restoration Questions bocoogto 08/18/15 11:21 PM
Re: '68 Restoration Questions bocoogto 08/19/15 05:46 PM
Re: '68 Restoration Questions bocoogto 08/21/15 06:32 PM
Re: '68 Restoration Questions bocoogto 08/21/15 07:28 PM
Re: '68 Restoration Questions bocoogto 08/24/15 04:44 PM
Re: '68 Restoration Questions HaroldB 08/24/15 05:58 PM
Re: '68 Restoration Questions bocoogto 08/25/15 12:55 AM
Re: '68 Restoration Questions bocoogto 08/29/15 05:20 PM
Re: '68 Restoration Questions bocoogto 08/31/15 04:04 AM
Re: '68 Restoration Questions bocoogto 09/02/15 06:40 AM
Re: '68 Restoration Questions bocoogto 09/03/15 10:08 PM
Re: '68 Restoration Questions Robert 09/03/15 11:08 PM
Re: '68 Restoration Questions bocoogto 09/04/15 09:48 PM
Re: '68 Restoration Questions bocoogto 09/05/15 05:18 PM
Re: '68 Restoration Questions HaroldB 09/06/15 04:37 PM
Re: '68 Restoration Questions bocoogto 09/06/15 11:27 PM
Re: '68 Restoration Questions Robert 09/14/15 06:03 PM
Re: '68 Restoration Questions bocoogto 09/22/15 05:15 PM
Re: '68 Restoration Questions bocoogto 10/05/15 08:03 AM
Re: '68 Restoration Questions ped 09/06/15 03:15 PM
Re: '68 Restoration Questions bocoogto 09/08/15 07:48 AM
Re: '68 Restoration Questions bocoogto 09/14/15 04:52 AM
Re: '68 Restoration Questions bocoogto 09/14/15 05:23 AM
Re: '68 Restoration Questions bocoogto 09/15/15 12:59 AM
Re: '68 Restoration Questions bocoogto 10/05/15 08:09 AM
Re: '68 Restoration Questions bocoogto 10/05/15 06:08 PM
Re: '68 Restoration Questions 5.7CCI 10/05/15 06:28 PM
Re: '68 Restoration Questions bocoogto 10/05/15 06:42 PM
Re: '68 Restoration Questions 5.7CCI 10/05/15 07:16 PM
Re: '68 Restoration Questions HaroldB 10/05/15 08:11 PM
Re: '68 Restoration Questions 68tpls400 10/05/15 09:00 PM
Re: '68 Restoration Questions Jimc2002 10/06/15 12:42 AM
Re: '68 Restoration Questions bocoogto 10/07/15 05:31 AM
Re: '68 Restoration Questions Jimc2002 10/07/15 06:17 PM
Re: '68 Restoration Questions HaroldB 10/08/15 02:19 AM
Re: '68 Restoration Questions Jimc2002 10/08/15 04:12 AM
Re: '68 Restoration Questions bocoogto 10/08/15 06:43 PM
Re: '68 Restoration Questions HaroldB 10/08/15 07:56 PM
Re: '68 Restoration Questions Gordy 10/09/15 01:29 AM
Re: '68 Restoration Questions bocoogto 10/09/15 06:31 AM
Re: '68 Restoration Questions Gordy 10/09/15 01:52 PM
Re: '68 Restoration Questions bocoogto 10/10/15 08:26 PM
Re: '68 Restoration Questions Gus68 10/11/15 03:57 PM
Re: '68 Restoration Questions HaroldB 10/18/15 01:02 AM
Re: '68 Restoration Questions bocoogto 10/18/15 01:31 AM
Re: '68 Restoration Questions bocoogto 10/18/15 08:37 PM
Re: '68 Restoration Questions 68tpls400 10/19/15 06:03 PM
Re: '68 Restoration Questions bocoogto 10/19/15 07:12 PM
Re: '68 Restoration Questions bocoogto 10/22/15 01:37 AM
Re: '68 Restoration Questions Gus68 10/22/15 03:01 AM
Re: '68 Restoration Questions bocoogto 10/25/15 03:09 AM
Re: '68 Restoration Questions bocoogto 10/25/15 03:33 AM
Re: '68 Restoration Questions USMC_Ordy 10/26/15 04:49 PM
Re: '68 Restoration Questions Gus68 10/26/15 07:38 PM
Re: '68 Restoration Questions USMC_Ordy 10/26/15 10:03 PM
Re: '68 Restoration Questions bocoogto 10/26/15 09:36 PM
Re: '68 Restoration Questions bocoogto 10/26/15 10:45 PM
Re: '68 Restoration Questions Jimc2002 10/26/15 11:58 PM
Re: '68 Restoration Questions bocoogto 11/06/15 05:21 PM
Re: '68 Restoration Questions bigchief 11/06/15 07:19 PM
Re: '68 Restoration Questions bocoogto 11/06/15 05:24 PM
Re: '68 Restoration Questions HaroldB 11/06/15 06:16 PM
Re: '68 Restoration Questions 68tpls400 11/06/15 06:58 PM
Re: '68 Restoration Questions bocoogto 11/06/15 08:45 PM
Re: '68 Restoration Questions bocoogto 11/08/15 04:34 PM
Re: '68 Restoration Questions Flynbye 11/08/15 04:57 PM
Re: '68 Restoration Questions bocoogto 11/09/15 12:08 AM
Re: '68 Restoration Questions bocoogto 11/09/15 04:10 AM
Re: '68 Restoration Questions wovenweb 11/09/15 02:17 AM
Re: '68 Restoration Questions Flynbye 11/09/15 04:36 PM
Re: '68 Restoration Questions bocoogto 11/10/15 01:39 AM
Re: '68 Restoration Questions Flynbye 11/10/15 03:45 PM
Re: '68 Restoration Questions Flynbye 11/10/15 03:47 PM
Re: '68 Restoration Questions bocoogto 11/10/15 05:54 PM
Re: '68 Restoration Questions rohrt 11/10/15 05:54 PM
Re: '68 Restoration Questions bocoogto 11/11/15 01:03 AM
Re: '68 Restoration Questions rohrt 11/12/15 10:26 PM
Re: '68 Restoration Questions bocoogto 11/12/15 11:01 PM
Re: '68 Restoration Questions bocoogto 11/20/15 08:36 PM
Re: '68 Restoration Questions bocoogto 11/20/15 08:37 PM
Re: '68 Restoration Questions bocoogto 11/28/15 07:17 PM
Re: '68 Restoration Questions wovenweb 11/28/15 09:31 PM
Re: '68 Restoration Questions bocoogto 01/16/16 07:37 PM
Re: '68 Restoration Questions bigchief 01/17/16 12:09 AM
Re: '68 Restoration Questions bocoogto 01/18/16 08:50 PM
Re: '68 Restoration Questions bigchief 01/18/16 09:09 PM
Re: '68 Restoration Questions rohrt 01/18/16 11:01 PM
Re: '68 Restoration Questions bocoogto 01/19/16 09:38 PM
Re: '68 Restoration Questions bocoogto 01/25/16 08:20 PM
Re: '68 Restoration Questions 68tpls400 01/25/16 10:56 PM
Re: '68 Restoration Questions bocoogto 01/26/16 12:57 AM
Re: '68 Restoration Questions Dennis in Indiana 02/26/16 02:03 AM
Re: '68 Restoration Questions bocoogto 03/02/16 01:07 AM
Re: '68 Restoration Questions Dennis in Indiana 03/02/16 05:04 AM
Re: '68 Restoration Questions bocoogto 03/05/16 02:43 AM
Re: '68 Restoration Questions bocoogto 03/27/16 07:24 PM
Re: '68 Restoration Questions bocoogto 08/28/16 10:43 PM
Re: '68 Restoration Questions wovenweb 08/28/16 10:58 PM
Re: '68 Restoration Questions bigchief 08/29/16 01:04 AM
Re: '68 Restoration Questions bocoogto 08/30/16 07:46 PM
Re: '68 Restoration Questions bigchief 08/30/16 10:26 PM
Re: '68 Restoration Questions bocoogto 09/03/16 04:18 PM
Re: '68 Restoration Questions bocoogto 10/09/16 08:07 PM
Re: '68 Restoration Questions bocoogto 03/14/17 07:29 PM
Re: '68 Restoration Questions Gus68 03/14/17 08:35 PM
Re: '68 Restoration Questions bocoogto 03/15/17 07:03 AM
Re: '68 Restoration Questions Mushroombert 03/15/17 04:48 PM
Re: '68 Restoration Questions bocoogto 03/17/17 04:40 PM
Re: '68 Restoration Questions bocoogto 03/20/17 01:31 PM
Re: '68 Restoration Questions cme469 03/21/17 03:27 AM
Re: '68 Restoration Questions bocoogto 03/28/17 09:06 PM
Re: '68 Restoration Questions cme469 03/29/17 01:37 AM
Re: '68 Restoration Questions bocoogto 04/02/17 02:54 AM
Re: '68 Restoration Questions bocoogto 03/18/17 06:03 PM
Re: '68 Restoration Questions Geoff 03/19/17 12:58 AM
Re: '68 Restoration Questions salmon38 03/18/17 06:40 PM
Re: '68 Restoration Questions bocoogto 04/07/17 06:53 PM
Re: '68 Restoration Questions cme469 04/08/17 01:32 AM
Re: '68 Restoration Questions bigchief 04/08/17 02:56 AM
Re: '68 Restoration Questions bocoogto 04/27/17 04:07 AM
Re: '68 Restoration Questions bocoogto 04/27/17 05:24 PM
Re: '68 Restoration Questions bocoogto 05/14/17 02:26 PM
Re: '68 Restoration Questions Jimc2002 05/14/17 03:05 PM
Re: '68 Restoration Questions bocoogto 10/15/17 02:10 AM
Re: '68 Restoration Questions bigchief 10/15/17 03:38 AM
Re: '68 Restoration Questions bocoogto 10/22/17 04:50 PM
