Frankie1968 #329019 02/01/21 12:55 PM
I re read and you are right. But it still holds true a Traction lock rear turns harder in neutral and easier with driveshaft disconnected.. 2. If you read the rtv specs each color tells you what they are designed for. As far as weight and quantity that is readily available info. Hear is a great source, the 68 Pontiac service manual on Harold B's site https://www.firebird400ho.com/mdocuments-library/ Then you can roughly buy the correct amount and fill to the check/fill hole. Before you pull the axle you can do a rough check on the condition of the locking cones and springs by grabbing hold of the axle face while someone is holding the other one and twist to see how easy the axles break apart. This is a subjective test because if you have two weak people it can change the outcome.
New Guy Frankie1968 01/02/21 07:33 PM
Re: New Guy Frankie1968 01/02/21 07:37 PM
Re: New Guy Duff 01/02/21 09:12 PM
Re: New Guy Frankie1968 01/02/21 10:48 PM
Re: New Guy Frankie1968 01/02/21 10:50 PM
Re: New Guy barnbird 01/03/21 12:02 AM
Re: New Guy Frankie1968 01/03/21 01:50 AM
Re: New Guy barnbird 01/03/21 03:14 PM
Re: New Guy Frankie1968 01/03/21 04:58 PM
Re: New Guy barnbird 01/03/21 05:03 PM
Re: New Guy Frankie1968 01/03/21 09:17 PM
small milestone Frankie1968 01/09/21 10:05 PM
Re: small milestone barnbird 01/10/21 02:40 AM
Re: small milestone Frankie1968 01/10/21 05:23 PM
Re: small milestone barnbird 01/10/21 06:07 PM
Advise needed Frankie1968 01/10/21 06:14 PM
Re: Advise needed barnbird 01/10/21 06:30 PM
Re: Advise needed Frankie1968 01/10/21 09:53 PM
Re: Advise needed barnbird 01/10/21 09:58 PM
Re: Advise needed Frankie1968 01/10/21 11:06 PM
small update Frankie1968 01/09/21 06:31 PM
Re: small update Frankie1968 01/09/21 06:37 PM
Backwards progress Frankie1968 01/11/21 10:45 PM
craigslist Frankie1968 01/12/21 03:23 PM
Small win Frankie1968 01/12/21 07:52 PM
Re: Small win barnbird 01/12/21 08:00 PM
Re: Small win Duff 01/12/21 11:57 PM
Re: Small win Frankie1968 01/14/21 12:04 AM
Parts car Frankie1968 01/14/21 12:08 AM
Re: Small win Duff 01/14/21 01:29 PM
Re: Small win Frankie1968 01/14/21 11:40 PM
Trunk pan Frankie1968 01/14/21 11:59 PM
Drive you crazy? Frankie1968 01/15/21 03:15 PM
ouch Frankie1968 01/16/21 05:27 PM
Re: ouch barnbird 01/16/21 07:25 PM
Re: ouch Frankie1968 01/17/21 06:34 PM
rear quarter louvers Frankie1968 01/18/21 06:06 PM
Re: rear quarter louvers 68tpls400 01/18/21 06:49 PM
Re: rear quarter louvers Sleddog 01/21/21 04:45 PM
Re: rear quarter louvers Frankie1968 01/22/21 08:16 PM
Re: rear quarter louvers 68tpls400 01/22/21 08:30 PM
Re: rear quarter louvers Frankie1968 01/23/21 04:58 PM
Re: rear quarter louvers Amervo 01/25/21 05:22 AM
Re: rear quarter louvers Amervo 01/25/21 05:27 AM
Re: rear quarter louvers Amervo 01/25/21 05:34 AM
Re: rear quarter louvers Amervo 01/25/21 05:47 AM
Re: rear quarter louvers Amervo 01/25/21 05:57 AM
Re: rear quarter louvers Frankie1968 01/27/21 01:50 AM
Re: rear quarter louvers barnbird 01/27/21 07:11 PM
Re: rear quarter louvers Frankie1968 01/27/21 07:23 PM
Re: rear quarter louvers barnbird 01/27/21 07:26 PM
Re: rear quarter louvers Jimc2002 01/18/21 11:10 PM
Re: rear quarter louvers Frankie1968 01/19/21 07:10 PM
Re: rear quarter louvers barnbird 01/19/21 07:33 PM
Rust bucket Frankie1968 01/19/21 11:33 PM
Re: Rust bucket barnbird 01/20/21 12:11 AM
Re: Rust bucket Frankie1968 01/20/21 05:51 PM
Re: Rust bucket barnbird 01/20/21 07:31 PM
another small win Frankie1968 01/27/21 07:39 PM
Re: another small win barnbird 01/28/21 01:13 AM
Re: another small win Frankie1968 01/28/21 05:33 PM
Rear end id Frankie1968 01/29/21 05:07 PM
Re: Rear end id barnbird 01/29/21 07:47 PM
Re: Rear end id Frankie1968 01/29/21 10:19 PM
Re: Rear end id barnbird 01/29/21 11:48 PM
Re: Rear end id Frankie1968 01/30/21 02:49 AM
Re: Rear end id Frankie1968 01/30/21 08:36 PM
Re: Rear end id barnbird 01/30/21 10:11 PM
Re: Rear end id Frankie1968 02/01/21 02:13 AM
Re: Rear end id barnbird 02/01/21 04:55 PM
oh crap Frankie1968 02/01/21 10:49 PM
Re: oh crap Jimc2002 02/02/21 12:43 AM
Re: oh crap Frankie1968 02/02/21 04:15 AM
Re: oh crap barnbird 02/02/21 01:20 AM
Re: oh crap Frankie1968 02/02/21 04:13 AM
Re: oh crap Frankie1968 02/02/21 04:26 AM
Re: oh crap barnbird 02/02/21 04:56 PM
Re: oh crap Frankie1968 02/02/21 06:20 PM
Re: oh crap barnbird 02/02/21 06:00 PM
Re: oh crap Frankie1968 02/02/21 06:51 PM
Rock auto Frankie1968 02/02/21 07:06 PM
Re: oh crap barnbird 02/02/21 08:26 PM
Re: oh crap Frankie1968 02/02/21 08:56 PM
Re: oh crap barnbird 02/02/21 11:12 PM
Re: oh crap Frankie1968 02/02/21 11:31 PM
Re: oh crap barnbird 02/03/21 12:00 AM
axle bearing Frankie1968 02/03/21 01:47 AM
Re: oh crap barnbird 02/02/21 01:29 AM
Re: another small win nashville68bird 02/03/21 03:48 AM
Re: another small win Frankie1968 02/03/21 03:08 PM
Barnbird Frankie1968 02/03/21 08:55 PM
axle Frankie1968 02/04/21 08:01 PM
Re: axle hokie1984 02/05/21 01:22 AM
Re: axle Frankie1968 02/05/21 06:35 PM
Front drum question Frankie1968 02/09/21 03:42 AM
Re: Front drum question barnbird 02/09/21 06:30 PM
Re: Front drum question Dr. Drivability 02/09/21 06:46 PM
Do I win? Frankie1968 02/09/21 11:26 PM
Re: Do I win? cme469 02/10/21 12:16 AM
Re: Do I win? Frankie1968 02/10/21 05:36 PM
Re: Do I win? Jimc2002 02/10/21 05:51 PM
axle shim Frankie1968 02/10/21 11:26 PM
Head id Frankie1968 02/10/21 11:30 PM
Ames Frankie1968 02/11/21 04:58 PM
plug wired Frankie1968 02/11/21 09:48 PM
head id Frankie1968 02/13/21 01:49 AM
bearing retainer Frankie1968 02/15/21 08:11 PM
Re: bearing retainer Frankie1968 02/15/21 10:26 PM
what is it worth? Frankie1968 02/16/21 12:46 AM
Fumes Frankie1968 02/16/21 05:33 PM
Re: Fumes Frankie1968 02/19/21 01:34 AM
Re: Fumes barnbird 02/19/21 06:17 PM
Re: Fumes Frankie1968 02/19/21 10:18 PM
Re: Fumes barnbird 02/19/21 10:48 PM
Re: Fumes Amervo 02/20/21 02:43 PM
Re: Fumes Frankie1968 02/20/21 06:40 PM
Re: Fumes Frankie1968 02/20/21 06:35 PM
Re: Fumes barnbird 02/20/21 07:34 PM
Re: Fumes Frankie1968 02/20/21 07:51 PM
Re: Fumes barnbird 02/20/21 08:04 PM
pinion seal Frankie1968 02/22/21 04:56 PM
header Frankie1968 02/22/21 11:37 PM
Re: header Frankie1968 02/27/21 04:05 PM
Re: header Duff 02/28/21 01:13 PM
Re: header Frankie1968 02/28/21 05:47 PM
craigslist Frankie1968 02/28/21 05:54 PM
Re: craigslist RckstrRobbie 02/28/21 10:16 PM
Re: craigslist Frankie1968 02/28/21 10:54 PM
Re: craigslist Sleddog 03/01/21 05:00 PM
Re: craigslist barnbird 03/01/21 07:56 PM
axle bearing lock ring Frankie1968 03/05/21 08:04 PM
Re: axle bearing lock ring hokie1984 03/06/21 01:33 AM
Re: axle bearing lock ring Frankie1968 03/06/21 04:37 PM
Re: axle bearing lock ring barnbird 03/06/21 04:41 PM
Re: axle bearing lock ring Frankie1968 03/06/21 09:51 PM
Re: axle bearing lock ring barnbird 03/06/21 11:56 PM
Re: axle bearing lock ring Frankie1968 03/08/21 01:38 AM
Re: axle bearing lock ring barnbird 03/08/21 05:47 PM
Re: axle bearing lock ring Frankie1968 03/08/21 10:57 PM
carb Frankie1968 03/09/21 01:18 AM
Re: carb carter Frankie1968 03/09/21 01:45 AM
Re: carb carter barnbird 03/09/21 02:16 AM
Re: carb carter Frankie1968 03/09/21 02:42 AM
Re: carb carter barnbird 03/09/21 03:49 AM
Re: axle bearing lock ring barnbird 03/09/21 01:22 AM
Re: axle bearing lock ring Frankie1968 03/09/21 02:02 AM
Re: axle bearing lock ring barnbird 03/09/21 02:42 AM
Re: axle bearing lock ring Frankie1968 03/09/21 03:12 AM
Re: axle bearing lock ring barnbird 03/09/21 03:38 AM
Re: axle bearing lock ring Frankie1968 03/09/21 04:00 AM
Re: axle bearing lock ring barnbird 03/09/21 04:09 AM
scumbag Frankie1968 03/09/21 11:21 PM
Re: scumbag barnbird 03/10/21 05:15 PM
Re: scumbag Frankie1968 03/10/21 07:16 PM
Hey Barnbird Frankie1968 03/10/21 07:23 PM
Re: Hey Barnbird hokie1984 03/11/21 12:27 AM
Re: Hey Barnbird Frankie1968 03/11/21 03:16 AM
Re: Hey Barnbird barnbird 03/11/21 03:49 PM
Re: Hey Barnbird Frankie1968 03/13/21 09:15 PM
Houstin we have a big problem Frankie1968 03/13/21 09:32 PM
Re: Houstin we have a big problem hokie1984 03/14/21 12:34 AM
Re: Houstin we have a big problem Frankie1968 03/14/21 11:03 PM
Re: Houstin we have a big problem Frankie1968 03/15/21 04:01 PM
Re: Houstin we have a big problem Jimc2002 03/15/21 04:36 PM
Re: Houstin we have a big problem barnbird 03/15/21 04:53 PM
new axle information Frankie1968 03/20/21 05:03 PM
Re: new axle information Duff 03/20/21 05:16 PM
Re: new axle information Frankie1968 03/20/21 10:45 PM
Re: Houstin we have a big problem cme469 03/15/21 04:53 PM
Re: Houstin we have a big problem barnbird 03/15/21 05:20 PM
Re: Houstin we have a big problem Frankie1968 03/15/21 07:45 PM
Re: Houstin we have a big problem barnbird 03/15/21 11:00 PM
Re: Houstin we have a big problem Frankie1968 03/16/21 01:39 PM
Axle solution Frankie1968 03/16/21 08:46 PM
This flippen new Ames axle Frankie1968 03/18/21 07:34 PM
Re: This flippen new Ames axle barnbird 03/18/21 10:17 PM
Re: This flippen new Ames axle Frankie1968 03/18/21 10:55 PM
Re: This flippen new Ames axle barnbird 03/18/21 11:04 PM
Re: This flippen new Ames axle Frankie1968 03/19/21 01:59 AM
Re: This flippen new Ames axle Duff 03/20/21 04:16 PM
Re: This flippen new Ames axle Frankie1968 03/20/21 04:45 PM
Re: This flippen new Ames axle Frankie1968 03/22/21 09:35 PM
My final post on the new Ames axle Frankie1968 03/24/21 10:53 PM
Re: My final post on the new Ames axle Sleddog 03/25/21 05:13 PM
Re: My final post on the new Ames axle Frankie1968 03/27/21 03:13 PM
Re: Houstin we have a big problem cme469 04/06/21 06:37 PM
Re: Houstin we have a big problem Frankie1968 04/08/21 02:58 AM
Surprise it started Frankie1968 04/21/21 07:42 PM
Re: Surprise it started Sleddog 04/23/21 01:07 PM
Re: Surprise it started Frankie1968 04/25/21 01:51 AM
Re: Surprise it started Sleddog 04/27/21 10:37 PM
Re: Surprise it started Frankie1968 04/29/21 10:01 PM
Re: Surprise it started Sleddog 05/01/21 04:36 AM
Rear quarter skins Frankie1968 05/17/21 07:38 PM
quadrajet update Frankie1968 05/31/21 08:59 PM
Re: Hey Barnbird barnbird 03/11/21 05:20 PM
Re: Fumes barnbird 02/20/21 08:33 PM
Re: Fumes Frankie1968 02/20/21 10:19 PM
Re: Fumes hokie1984 02/20/21 11:52 PM
Re: Fumes Frankie1968 02/21/21 01:16 AM
Re: Fumes hokie1984 02/21/21 10:50 PM
Re: Fumes Frankie1968 02/21/21 11:02 PM
Re: bearing retainer Frankie1968 02/19/21 01:22 AM
Re: Front drum question Frankie1968 02/09/21 11:09 PM
Re: rear quarter louvers barnbird 01/19/21 05:22 PM
