Thanks,
Original 4 piston front brakes are not even on the table.( hence the poor mans front discs) I will use my stock drum spindles and they don't need any modification.
I think i will end up using this kit
https://scarebird.com/index.php?route=product/product&product_id=67
I need to confirm but i think this kit makes the front track width a bit narrower instead of moving the offset outward like other kits.
I had stock single piston nova front discs on my 67 BBC camaro i used to have and i was impressed with the stopping power.I assume these single piston small rotor kits should be close in performance and good enough for me. Certainly better then drums.
As far as separating my worn out drums from their hubs my research shows normal style rotors are much cheaper then the one piece i need to buy for this kit.
I will probably not waste my time trying to separate my hubs but we will see.
So all this disc upgrade idea has come as a result of trying to get my crappy drum brakes to work again. The front left i ended up swapping the whole backing plate assembly from my other sub frame after the wheel cylinder blew. Why not buy a new wheel cylinder?
Simple, i do not want to put any money into the front drum brakes at all, i just wanted to be able to move this parts car around the yard safely.
And some kind of front disc upgrade was always in the plans .
Now onto the front right side. This side was even worse with another seized wheel cylinder, Drum is worn thin, and the wheel bearing was dragging badly. Since my other sub-frame is now under the snow this side will have to wait.
All the brake-work i do will eventually transfer to the other shell.
So I found my self looking at the crappy header on the passenger side.
New Guy Frankie1968 01/02/21 07:33 PM
Re: New Guy Frankie1968 01/02/21 07:37 PM
Re: New Guy Duff 01/02/21 09:12 PM
Re: New Guy Frankie1968 01/02/21 10:48 PM
Re: New Guy Frankie1968 01/02/21 10:50 PM
Re: New Guy barnbird 01/03/21 12:02 AM
Re: New Guy Frankie1968 01/03/21 01:50 AM
Re: New Guy barnbird 01/03/21 03:14 PM
Re: New Guy Frankie1968 01/03/21 04:58 PM
Re: New Guy barnbird 01/03/21 05:03 PM
Re: New Guy Frankie1968 01/03/21 09:17 PM
small milestone Frankie1968 01/09/21 10:05 PM
Re: small milestone barnbird 01/10/21 02:40 AM
Re: small milestone Frankie1968 01/10/21 05:23 PM
Re: small milestone barnbird 01/10/21 06:07 PM
Advise needed Frankie1968 01/10/21 06:14 PM
Re: Advise needed barnbird 01/10/21 06:30 PM
Re: Advise needed Frankie1968 01/10/21 09:53 PM
Re: Advise needed barnbird 01/10/21 09:58 PM
Re: Advise needed Frankie1968 01/10/21 11:06 PM
small update Frankie1968 01/09/21 06:31 PM
Re: small update Frankie1968 01/09/21 06:37 PM
Backwards progress Frankie1968 01/11/21 10:45 PM
craigslist Frankie1968 01/12/21 03:23 PM
Small win Frankie1968 01/12/21 07:52 PM
Re: Small win barnbird 01/12/21 08:00 PM
Re: Small win Duff 01/12/21 11:57 PM
Re: Small win Frankie1968 01/14/21 12:04 AM
Parts car Frankie1968 01/14/21 12:08 AM
Re: Small win Duff 01/14/21 01:29 PM
Re: Small win Frankie1968 01/14/21 11:40 PM
Trunk pan Frankie1968 01/14/21 11:59 PM
Drive you crazy? Frankie1968 01/15/21 03:15 PM
ouch Frankie1968 01/16/21 05:27 PM
Re: ouch barnbird 01/16/21 07:25 PM
Re: ouch Frankie1968 01/17/21 06:34 PM
rear quarter louvers Frankie1968 01/18/21 06:06 PM
Re: rear quarter louvers 68tpls400 01/18/21 06:49 PM
Re: rear quarter louvers Sleddog 01/21/21 04:45 PM
Re: rear quarter louvers Frankie1968 01/22/21 08:16 PM
Re: rear quarter louvers 68tpls400 01/22/21 08:30 PM
Re: rear quarter louvers Frankie1968 01/23/21 04:58 PM
Re: rear quarter louvers Amervo 01/25/21 05:22 AM
Re: rear quarter louvers Amervo 01/25/21 05:27 AM
Re: rear quarter louvers Amervo 01/25/21 05:34 AM
Re: rear quarter louvers Amervo 01/25/21 05:47 AM
Re: rear quarter louvers Amervo 01/25/21 05:57 AM
Re: rear quarter louvers Frankie1968 01/27/21 01:50 AM
Re: rear quarter louvers barnbird 01/27/21 07:11 PM
Re: rear quarter louvers Frankie1968 01/27/21 07:23 PM
Re: rear quarter louvers barnbird 01/27/21 07:26 PM
Re: rear quarter louvers Jimc2002 01/18/21 11:10 PM
Re: rear quarter louvers Frankie1968 01/19/21 07:10 PM
Re: rear quarter louvers barnbird 01/19/21 07:33 PM
Rust bucket Frankie1968 01/19/21 11:33 PM
Re: Rust bucket barnbird 01/20/21 12:11 AM
Re: Rust bucket Frankie1968 01/20/21 05:51 PM
Re: Rust bucket barnbird 01/20/21 07:31 PM
another small win Frankie1968 01/27/21 07:39 PM
Re: another small win barnbird 01/28/21 01:13 AM
Re: another small win Frankie1968 01/28/21 05:33 PM
Rear end id Frankie1968 01/29/21 05:07 PM
Re: Rear end id barnbird 01/29/21 07:47 PM
Re: Rear end id Frankie1968 01/29/21 10:19 PM
Re: Rear end id barnbird 01/29/21 11:48 PM
Re: Rear end id Frankie1968 01/30/21 02:49 AM
Re: Rear end id Frankie1968 01/30/21 08:36 PM
Re: Rear end id barnbird 01/30/21 10:11 PM
Re: Rear end id Frankie1968 02/01/21 02:13 AM
Re: Rear end id barnbird 02/01/21 04:55 PM
oh crap Frankie1968 02/01/21 10:49 PM
Re: oh crap Jimc2002 02/02/21 12:43 AM
Re: oh crap Frankie1968 02/02/21 04:15 AM
Re: oh crap barnbird 02/02/21 01:20 AM
Re: oh crap Frankie1968 02/02/21 04:13 AM
Re: oh crap Frankie1968 02/02/21 04:26 AM
Re: oh crap barnbird 02/02/21 04:56 PM
Re: oh crap Frankie1968 02/02/21 06:20 PM
Re: oh crap barnbird 02/02/21 06:00 PM
Re: oh crap Frankie1968 02/02/21 06:51 PM
Rock auto Frankie1968 02/02/21 07:06 PM
Re: oh crap barnbird 02/02/21 08:26 PM
Re: oh crap Frankie1968 02/02/21 08:56 PM
Re: oh crap barnbird 02/02/21 11:12 PM
Re: oh crap Frankie1968 02/02/21 11:31 PM
Re: oh crap barnbird 02/03/21 12:00 AM
axle bearing Frankie1968 02/03/21 01:47 AM
Re: oh crap barnbird 02/02/21 01:29 AM
Re: another small win nashville68bird 02/03/21 03:48 AM
Re: another small win Frankie1968 02/03/21 03:08 PM
Barnbird Frankie1968 02/03/21 08:55 PM
axle Frankie1968 02/04/21 08:01 PM
Re: axle hokie1984 02/05/21 01:22 AM
Re: axle Frankie1968 02/05/21 06:35 PM
Front drum question Frankie1968 02/09/21 03:42 AM
Re: Front drum question barnbird 02/09/21 06:30 PM
Re: Front drum question Dr. Drivability 02/09/21 06:46 PM
Do I win? Frankie1968 02/09/21 11:26 PM
Re: Do I win? cme469 02/10/21 12:16 AM
Re: Do I win? Frankie1968 02/10/21 05:36 PM
Re: Do I win? Jimc2002 02/10/21 05:51 PM
axle shim Frankie1968 02/10/21 11:26 PM
Head id Frankie1968 02/10/21 11:30 PM
Ames Frankie1968 02/11/21 04:58 PM
plug wired Frankie1968 02/11/21 09:48 PM
head id Frankie1968 02/13/21 01:49 AM
bearing retainer Frankie1968 02/15/21 08:11 PM
Re: bearing retainer Frankie1968 02/15/21 10:26 PM
what is it worth? Frankie1968 02/16/21 12:46 AM
Fumes Frankie1968 02/16/21 05:33 PM
Re: Fumes Frankie1968 02/19/21 01:34 AM
Re: Fumes barnbird 02/19/21 06:17 PM
Re: Fumes Frankie1968 02/19/21 10:18 PM
Re: Fumes barnbird 02/19/21 10:48 PM
Re: Fumes Amervo 02/20/21 02:43 PM
Re: Fumes Frankie1968 02/20/21 06:40 PM
Re: Fumes Frankie1968 02/20/21 06:35 PM
Re: Fumes barnbird 02/20/21 07:34 PM
Re: Fumes Frankie1968 02/20/21 07:51 PM
Re: Fumes barnbird 02/20/21 08:04 PM
pinion seal Frankie1968 02/22/21 04:56 PM
header Frankie1968 02/22/21 11:37 PM
Re: header Frankie1968 02/27/21 04:05 PM
Re: header Duff 02/28/21 01:13 PM
Re: header Frankie1968 02/28/21 05:47 PM
craigslist Frankie1968 02/28/21 05:54 PM
Re: craigslist RckstrRobbie 02/28/21 10:16 PM
Re: craigslist Frankie1968 02/28/21 10:54 PM
Re: craigslist Sleddog 03/01/21 05:00 PM
Re: craigslist barnbird 03/01/21 07:56 PM
axle bearing lock ring Frankie1968 03/05/21 08:04 PM
Re: axle bearing lock ring hokie1984 03/06/21 01:33 AM
Re: axle bearing lock ring Frankie1968 03/06/21 04:37 PM
Re: axle bearing lock ring barnbird 03/06/21 04:41 PM
Re: axle bearing lock ring Frankie1968 03/06/21 09:51 PM
Re: axle bearing lock ring barnbird 03/06/21 11:56 PM
Re: axle bearing lock ring Frankie1968 03/08/21 01:38 AM
Re: axle bearing lock ring barnbird 03/08/21 05:47 PM
Re: axle bearing lock ring Frankie1968 03/08/21 10:57 PM
carb Frankie1968 03/09/21 01:18 AM
Re: carb carter Frankie1968 03/09/21 01:45 AM
Re: carb carter barnbird 03/09/21 02:16 AM
Re: carb carter Frankie1968 03/09/21 02:42 AM
Re: carb carter barnbird 03/09/21 03:49 AM
Re: axle bearing lock ring barnbird 03/09/21 01:22 AM
Re: axle bearing lock ring Frankie1968 03/09/21 02:02 AM
Re: axle bearing lock ring barnbird 03/09/21 02:42 AM
Re: axle bearing lock ring Frankie1968 03/09/21 03:12 AM
Re: axle bearing lock ring barnbird 03/09/21 03:38 AM
Re: axle bearing lock ring Frankie1968 03/09/21 04:00 AM
Re: axle bearing lock ring barnbird 03/09/21 04:09 AM
scumbag Frankie1968 03/09/21 11:21 PM
Re: scumbag barnbird 03/10/21 05:15 PM
Re: scumbag Frankie1968 03/10/21 07:16 PM
Hey Barnbird Frankie1968 03/10/21 07:23 PM
Re: Hey Barnbird hokie1984 03/11/21 12:27 AM
Re: Hey Barnbird Frankie1968 03/11/21 03:16 AM
Re: Hey Barnbird barnbird 03/11/21 03:49 PM
Re: Hey Barnbird Frankie1968 03/13/21 09:15 PM
Houstin we have a big problem Frankie1968 03/13/21 09:32 PM
Re: Houstin we have a big problem hokie1984 03/14/21 12:34 AM
Re: Houstin we have a big problem Frankie1968 03/14/21 11:03 PM
Re: Houstin we have a big problem Frankie1968 03/15/21 04:01 PM
Re: Houstin we have a big problem Jimc2002 03/15/21 04:36 PM
Re: Houstin we have a big problem barnbird 03/15/21 04:53 PM
new axle information Frankie1968 03/20/21 05:03 PM
Re: new axle information Duff 03/20/21 05:16 PM
Re: new axle information Frankie1968 03/20/21 10:45 PM
Re: Houstin we have a big problem cme469 03/15/21 04:53 PM
Re: Houstin we have a big problem barnbird 03/15/21 05:20 PM
Re: Houstin we have a big problem Frankie1968 03/15/21 07:45 PM
Re: Houstin we have a big problem barnbird 03/15/21 11:00 PM
Re: Houstin we have a big problem Frankie1968 03/16/21 01:39 PM
Axle solution Frankie1968 03/16/21 08:46 PM
This flippen new Ames axle Frankie1968 03/18/21 07:34 PM
Re: This flippen new Ames axle barnbird 03/18/21 10:17 PM
Re: This flippen new Ames axle Frankie1968 03/18/21 10:55 PM
Re: This flippen new Ames axle barnbird 03/18/21 11:04 PM
Re: This flippen new Ames axle Frankie1968 03/19/21 01:59 AM
Re: This flippen new Ames axle Duff 03/20/21 04:16 PM
Re: This flippen new Ames axle Frankie1968 03/20/21 04:45 PM
Re: This flippen new Ames axle Frankie1968 03/22/21 09:35 PM
My final post on the new Ames axle Frankie1968 03/24/21 10:53 PM
Re: My final post on the new Ames axle Sleddog 03/25/21 05:13 PM
Re: My final post on the new Ames axle Frankie1968 03/27/21 03:13 PM
Re: Houstin we have a big problem cme469 04/06/21 06:37 PM
Re: Houstin we have a big problem Frankie1968 04/08/21 02:58 AM
Surprise it started Frankie1968 04/21/21 07:42 PM
Re: Surprise it started Sleddog 04/23/21 01:07 PM
Re: Surprise it started Frankie1968 04/25/21 01:51 AM
Re: Surprise it started Sleddog 04/27/21 10:37 PM
Re: Surprise it started Frankie1968 04/29/21 10:01 PM
Re: Surprise it started Sleddog 05/01/21 04:36 AM
Rear quarter skins Frankie1968 05/17/21 07:38 PM
quadrajet update Frankie1968 05/31/21 08:59 PM
Re: Hey Barnbird barnbird 03/11/21 05:20 PM
Re: Fumes barnbird 02/20/21 08:33 PM
Re: Fumes Frankie1968 02/20/21 10:19 PM
Re: Fumes hokie1984 02/20/21 11:52 PM
Re: Fumes Frankie1968 02/21/21 01:16 AM
Re: Fumes hokie1984 02/21/21 10:50 PM
Re: Fumes Frankie1968 02/21/21 11:02 PM
Re: bearing retainer Frankie1968 02/19/21 01:22 AM
Re: Front drum question Frankie1968 02/09/21 11:09 PM
Re: rear quarter louvers barnbird 01/19/21 05:22 PM
